Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th August 2003, 04:56 PM   #1
Default What to do with unused MCU I/Os
I'm building a DAC which uses a PIC18F448. The design is not going to require the use of all the I/Os, so I was wondering what the best practice would be with regards to them. Should they be left floating or grounded? Seems to me it would be far wiser to ground them, but maybe I'm missing something.
Stu
Old 4th August 2003, 05:09 PM   #2
bocka is offline bocka  Germany
Use a pull-up resistor or better a resistor-network to +Vdd. About 10k, value is not critical. Never left an input port open untill you're shure it got an internal pull-up or -down
Old 5th August 2003, 07:40 AM   #3
MWP is offline MWP  Australia
Read the PIC manuals... they normally state how unused pins should be connected.
Most newer uC's dont require any pull up/downs.
Old 5th August 2003, 09:56 AM   #4
I'd connect the spare IO lines to LEDs to help with code debugging: light them when you reach a breakpoint, that kind of thing.
Nice one,
David.
Old 5th August 2003, 05:36 PM   #5
Default Re: What to do with unused MCU I/Os
Stu
Select a PIC that likes to sleep and power it down to sleep mode when unused.
If you want to terminate the pins: Make sure the are logically low, and connect them to ground, as much of them as possible.
regards
Guido Tent
www.Tentlabs.com
Old 5th August 2003, 06:56 PM   #6
Thanks everybody! I think I'll ground them then as originally planned.
Stu
Old 5th August 2003, 07:36 PM   #7
Stu
Stu
OK, but realize yourself that it only makes sense once you make them actively low
regards
Guido Tent
www.Tentlabs.com
Old 5th August 2003, 10:01 PM   #8
Originally posted by Guido Tent
Stu
regards
Hi Guido,
So are you saying it would be just as good to leave it floating if the pins are not used in the code? I just don't want them wandering all over the place, spitting noise into the system and possibly wasting power (this is a battery powered application).
Stu
Old 5th August 2003, 10:24 PM   #9
seangoesbonk's Avatar
You can do one of two things with unused I/O pins:
1. Configure them as inputs and connect them to Vdd or Vss via pull up (or down) resistors, or
2. Configure them as outputs, drive them high or low, (in your software) and do not connect them to anything. They will not "wander".
If you make them outputs and connect them to ground (or Vdd), you could have a big problem if the pin is driven high. (on startup or otherwise)
Edit: Check out the "Low Power Solutions Design Center" at Microchip's web site: http://www.microchip.com/1010/suppdo...wpwr/index.htm
My girlfriend's sub is bigger than mine...
Old 6th August 2003, 01:54 AM   #10
Thanks for the suggestions and the link - very helpful.
Stu
FS: new and unused TDA1541A S1 SSassen Swap Meet 9 20th January 2010 07:02 PM
enABL kit. Unused. nodiak Swap Meet 3 23rd January 2009 07:10 PM
Unused secondaries pilli Parts 8 7th October 2007 10:14 AM
Superclock Ii - Unused leeo666 Swap Meet 0 19th July 2006 11:05 AM
Page generated in 0.09791 seconds (81.20% PHP - 18.80% MySQL) with 10 queries
