Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th March 2011, 05:29 AM   #1
Default cheap DIY-able usb spdif-out mod
I have been hacking c-media usb chips for a little while now. they are cool
some photos of how simple it can be to tap into the cm102 usb audio chip. some more expensive ones come with toslink but those that dont can have it added pretty easily:
the last photo shows a diff chipset; cm108. little harder to hack due to pin pitch and I throw it all on a piece of acrylic and had a small perf helper board for strain relief. looks silly but works just fine and was cheap (usb sound card was $10 or so).
(ignore the seagate dockstar in the photo. its running linux but not relevant to the usb audio thing; just happened to be in the photo).
if you can somehow know that the usb dongle you are buying is a real cm102 or cm108, then you can get yourself a cheap spdif toslink out for the price of a TOTX 5v based sender. that's usually in the dollar range.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 28th March 2011, 10:49 AM   #2
You got too many wires to the 108 one... why double up on the supply?
Old 28th March 2011, 01:37 PM   #3
because on the 108 one, I was also trying to tap into the i2s output!
was not able to do that fine of a soldering so I gave up, but that was the idea. I had to settle for spdif out on that one.
Old 28th March 2011, 02:38 PM   #4
between the 2 white molex headers is a red one. that was going to carry the i2s signals. the only places to tap were the chip pins, themselves. no pads or anything I could solder to.
someone else who can do smaller scale work could pull it off, though. I just can't, not with my meager home workbench.
Old 16th January 2012, 01:01 AM   #5
where did you get your sound card?
Old 16th January 2012, 01:11 AM   #6
you'll have to find your own source; they are not reliable over time, so even if I knew, chances are they would not have the same one again. pcb's change a lot and suppliers change a lot.
the vendors don't care, so its harder for us to find these. just be sure it has cm102 and maybe even a plus sign at the end.
Old 16th January 2012, 01:23 AM   #7
ddietz is offline ddietz  United States
May I ask what the point of this is... how do you use it?
I'm a noob with digital audio and I'm curious as to the application.
Old 16th January 2012, 01:45 AM   #8
if you want spdif as your sound card output instead of analog.
usually that means you have an outboard DAC box and you paid good money for it (and it performs well) and you'd just assume all your audio feeds be digital.
the cmedia chips are driverless and they appear as sound cards you can pick for movie or music use. the specialness is that these have built-in spdif outputs on them and are trivial to tap into.
hth.
Old 16th January 2012, 03:01 AM   #9
That's what I figured, thanks for the explanation. Is there any advantage to this if your motherboard already has s/pdif out?
Old 16th January 2012, 03:26 PM   #10
it depends on how good you think your motherboard spdif is. often, they are not isolated (almost never, in fact, are they trafo isolated and they really should be, if coax). if they are opto, do they use good opto parts or the lowest end ones? it may affect things.
is the chipset bit-perfect? most are these days but the driver may hide that and break things.
the cmedia driver is no driver. nothing has to be installed, no junkware and no layered apps. every os comes with usb audio built in. if you do see a 'search for drivers' CANCEL IT. cmedia should not need them. to me, that's worth even disabling the onboard one.
when I disable it, I do it in the BIOS, as well, and make sure the o/s does not see the mobo based sound device.
also, with usb, you have 100% manual control over mute. its called 'pulling the dongle out' (LOL!). I'm serious, too; if you get stuck in an app or something and you can't turn the sound off, you pull the usb dongle out and that stops the sound I like that with wifi, too. I KNOW my machine is not on the air if I pull out the wifi dongle. (on some laptops, they wake up, try to access the net and then shutdown even if you've turned off the NIC or shutdown the system. no nic == no phoning home at night.)
the most obvious use is on tiny little systems that are embedded and have no sound card at all. I have a linux ARM box (hacked seagate dockstar) and it has usb but no sound onboard. plug this thing in and you can now do spdif-out, on a tiny little fanless marvell plug-style computer.
Anyone interested in a general purpose DIY SPDIF/USB/ADC/DAC interface board using th allanw Digital Source 4 27th July 2010 07:47 AM
cheap spdif input dac to mod lordearl PC Based 6 29th April 2010 10:14 AM
spdif vs usb joshuajoshua Digital Source 28 19th December 2007 11:56 AM
Usb To Spdif etalon90 Digital Source 2 7th June 2004 09:40 PM
Page generated in 0.09117 seconds (88.52% PHP - 11.48% MySQL) with 10 queries
