Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 3rd January 2012, 07:58 AM   #821
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
Originally Posted by oneoclock View Post
I have no great knowledge about ground, but I think this layout AVCC mass could be a possibility.
interesting... well done!
could you post a bit more details to replicate your mod? what have you used, a dremel or something like that?
Apart from measurments, have you noticed any difference also in perceived SQ?
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 3rd January 2012, 08:07 AM   #822
borges is offline borges  Norway
Good!
The end plates are made from FR4 which has 100% metal on one side. Except for the logo, this metal is covered by white solder stop lacquer. It is not connected to the box.
For the next model I'll open up the metal around the connectors. And I'll connect the metal to the screws. This is easily done with a scalpel and the right screwdrivers (PH2 and TX10).
Now I realize the panels may act as patch antennas!
BÝrge
Old 3rd January 2012, 09:31 AM   #823
ElEsido is offline ElEsido  Switzerland
I've cutting edge copper of the back plate of the audio connectors and especially miniUSB. It was ended the problem.
Could you share a picture, please? Thanks!
Old 3rd January 2012, 09:46 AM   #824
alexlee188 is offline alexlee188  Canada
Intermodulation with 19 and 20 KHz. These measures are quite good.
For intermod measurements with 2 input signals, they should be at -3dB each instead of 0dB, I think.
Alex
Old 3rd January 2012, 11:15 AM   #825
oneoclock is offline oneoclock  Europe
oneoclock's Avatar
I Added 19 Khz -9 dBFS and 20 Khz -9 dBFS (32 bit).
After the sum normalized to 0 dBFS and 24 bit.
These are photos of detail: I hope you see.
Old 3rd January 2012, 12:56 PM   #826
Thanks oneoclock!
Old 3rd January 2012, 02:09 PM   #827
Oneoclock,
While you're at it, could you als check if exposing the front/back panel metal to the four screws improves on things?
(If you ruin your panels, I'll send you replacements!)
BÝrge
Old 3rd January 2012, 02:33 PM   #828
onoclock,
If you use LInux or OSX you can send the normalized 32 bit two-tone test direct to the AB1.1 (with the latest 32 bit firmware). See whether it makes any difference :-)
Alex
Old 3rd January 2012, 03:25 PM   #829
oneoclock's Avatar
There is no difference. I am concerned that red LED in to USB-I2S module turns off when I select 32 bit.
Its a problem?
Old 3rd January 2012, 03:28 PM   #830
oneoclock's Avatar
Originally Posted by borges View Post
Oneoclock,
BÝrge
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 07:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 03:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 08:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 11:24 PM
Copyright ©1999-2017 diyAudio
