Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 11th November 2011, 08:26 AM   #331
borges is offline borges  Norway
Picture?
Originally Posted by Turbon View Post
I'll have one of these when you are ready George. My ESS 9023 looks like Pearl Habour - 41 but it works so far. I have already downloaded the doc pack ;-)
Brgds
Old 11th November 2011, 08:47 AM   #332
Turbon is offline Turbon  Sweden
Turbon's Avatar
Originally Posted by borges View Post
Picture?
You wish Borges :-)
Another anomaly is this:
C:\Program Files\Atmel\Flip 3.4.3\bin>batchisp -device at32uc3a3256 -hardware usb -operation erase f memory flash blankcheck loadbuffer D:\projects\audio*\releas*\demo* program verify start reset 0
Running batchisp 1.2.5 on Fri Nov 11 10:41:29 2011
AT32UC3A3256 - USB - USB/DFU
Device selection....................... PASS
Hardware selection..................... PASS
Opening port........................... PASS
Reading Bootloader version............. PASS 1.0.3
Erasing................................ FAIL Could not read from USB device.
(A)bort, (R)etry, (I)gnore ? i
Selecting FLASH........................ PASS
Blank checking......................... FAIL Could not read from USB device.
FAIL Invalid or missing argument.
ISP done.
The flashled stuff worked great.
Brgds
BTW: The loading of flashblink did warn about overlapping code between bootloader and code... But it still worked.
Old 11th November 2011, 08:52 AM   #333
What sort of hardware are you seeing these problems on? I have _once_ seen a chip which couldn't erase.
Borge
Old 11th November 2011, 09:06 AM   #334
Turbon's Avatar
Borge
Georges USB9023 RevA
Brgds
Old 11th November 2011, 09:16 AM   #335
George, do you have a JTAG header on that board?
Turbon, the JTAG ICE mkII may tell you a bit more about what's going on. It is able to reflash the bootloader. But when I had the can't-erase problem, the JTAG didn't solve it for me.
Borge
Old 11th November 2011, 05:33 PM   #336
Turbon's Avatar
Borge
Thanks Borge - I'll look into it but here comes additional stuff:
Confession - pin 1 lead seems to be screwed - there is contact but it's the only problem i can see with 10x mag.
What about the jungo driver part - it asked me of what device i have... But if it worked for the blinkyflash - I can't see that there is a problem. Suppose it's allright - how do I choose to get the stream out of this device? Oh yes - I haven't figured out about the widget control part yet... It might be important but now I need some sleep.
Brgds and good night
Old 12th November 2011, 08:15 AM   #337
Turbon's Avatar
Good morning.
I will download a precompiled elf that is known to work since it can be some setting in the atmel ide that screws things up for me. Now which one should I pick?
Old 12th November 2011, 09:31 AM   #338
alexlee188 is offline alexlee188  Canada
audio-widget-nik-20111023.elf
Old 12th November 2011, 10:46 AM   #339
Turbon's Avatar
Thanks Alex. I went into the git repository but I can't find the elf...
Sorry about that but the project is a bit scattered for beginners.
I better google to find the file.
Brgds
Old 12th November 2011, 10:51 AM   #340
Yes, it is perhaps a bit fragmented... The download section is here:
Downloads - sdr-widget - Audio and Control Interface for Amateur Radio SDR and Audiophile USB-DAC - Google Project Hosting
The SDR Widget homepage has a link to github, but it doesn't come up as a link. Could someone with write permission change that, and perhaps add a link from github to the homepage as well?
Thanks,
BÝrge
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2017 diyAudio
