Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 8th June 2017, 07:21 PM   #2361
zdr is offline zdr  Belgium
zdr's Avatar
Ok, I found the instructions I think I flashed successfully the latest fw:
C:\Program Files (x86)\Atmel\Flip 3.4.7\bin>batchisp.exe -device at32uc3a3256 -h
ardware usb -operation erase f memory flash blankcheck loadbuffer awx_20160323_v
olume_control_0dB.elf
Running batchisp 1.2.5 on Thu Jun 08 18:17:01 2017
AT32UC3A3256 - USB - USB/DFU
Device selection....................... PASS
Hardware selection..................... PASS
Opening port........................... PASS
Reading Bootloader version............. PASS 1.0.3
Erasing................................ PASS
Selecting FLASH........................ PASS
Blank checking......................... PASS 0x00000 0x3ffff
Parsing ELF file....................... PASS awx_20160323_volume_control_0dB.
elf
Summary: Total 8 Passed 8 Failed 0
MCU is not showing under audio devices after reset, is that where it should appear? I can still see it under libusb-win32 devices as AT32UC3A3
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 9th June 2017, 08:28 AM   #2362
borges is offline borges  Norway
Hm,
you should download the Thesycon Descriptor Dumper to see which USB interfaces are actually present. The firmware you just downloaded makes the DAC identify itself as a Henry Audio device.
It sounds like it still boots into the bootloader and not the application. I'm not familiar enough with your programming method to say what may have gone wrong.
BÝrge
Old 9th June 2017, 08:32 AM   #2363
zdr's Avatar
Originally Posted by borges View Post
Hm,
BÝrge
Borge, I am now using your programming method with FLIP see my previous post. It does seem like it boots into bootloader every time. I tried another firmware and it behaves in the same way.
Old 9th June 2017, 08:36 AM   #2364
That is something I haven't seen before.
Honestly, I dislike the Flip method because of all the prerequisites. It's a big hassle to use, and I'd like to use something else. But it has to be stable first.
Have you reached out to avrfreaks about this?
BÝrge
Old 9th June 2017, 08:38 AM   #2365
zdr's Avatar
BÝrge
Which method do you recommend? Is there a 3rd way to flash a firmware I am not aware of? I haven't reached to avrfreaks, whatever that is
Old 9th June 2017, 09:13 AM   #2366
This far I have only used flip. It is a hassle to install, but works for me once wrapped in a .bat file. dfu-programmer.exe is something I haven't used, but would like to try.
It sounds to me like the programming you did failed to change a flag (or something like that) which makes the bootloader go ahead and execute the application and not the DFU.
Once or twice I have been able to update the bootloader with JTAG, but that is a tricky job which requires pins to be put in and the right Atmel file to be located.
AVRfreaks is a large community for Atmel programmers. I hope you may find some answers there or among the developers of dfu-programmer.
Please keep us posted. I'd like to be able to bypass flip and its cumbersome installation process. But it has to be with something which is stable.
BÝrge
Old 9th June 2017, 09:21 AM   #2367
zdr's Avatar
BÝrge
Thanks for the useful info. Now that I know what to expect, I can devise next steps.
1) Dfu programmer did a good job in flashing, but I don't know how to flash .elf files with it. It seems to expect hex files.
2) Flip was able to flash .elf, but it's booting in bootloader every time.
I will play with both variants and see where they get me.
Old 9th June 2017, 09:27 AM   #2368
OK, good luck!
Wild speculation makes me guess that the application was written to the wrong place in memory compared to what the bootloader expects, or that some flag bit wasn't properly modified.
Sorry that I can only offer you guesswork here..
BÝrge
Old 12th June 2017, 03:05 PM   #2369
zdr's Avatar
It was a mix of hardware (cold solder) and incomplete instructions for batchisp?? Program command was missing. This is now working:
ardware usb -operation erase f memory flash blankcheck loadbuffer awx_20140918_m
kII_RC03.elf program
Running batchisp 1.2.5 on Mon Jun 12 17:02:03 2017
Parsing ELF file....................... PASS awx_20140918_mkII_RC03.elf
WARNING: The user program and the bootloader overlap!
Programming memory..................... PASS 0x00000 0x1c987
Summary: Total 9 Passed 9 Failed 0
After this, I did a reset from dfu-programmer:
C:\dfu-programmer-win-0.7.2>dfu-programmer at32uc3a3256 reset --debug 4
target: at32uc3a3256
chip_id: 0x2ff1
vendor_id: 0x03eb
command: reset
quiet: false
debug: 4
device_type: AVR32
------ command specific below ------
It now shows under audio widget devices? Audio interface and Control Interface??
Old 12th June 2017, 03:18 PM   #2370
Great that you got it to work again!
BÝrge
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
