Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 2nd May 2014, 01:59 PM   #2311
greggp is offline greggp  United States
Send a message via MSN to greggp
Originally Posted by amb View Post
In case there is any confusion, the software to download and install is NOT the "VB-CABLE Driver". What you need is the "ASIO Bridge (Virtual Hi-Fi Cable And ASIO Bridge)".
This allows you to use any player software with the audio widget in UAC2 mode, even when there is no ASIO plugin available for the player.
The ASIO Bridge creates a virtual sound card interface "VB-Audio Hi-Fi Cable" which you should set up your player software to use as the output device. Then, start up the ASIO Bridge panel, set its output device to "ASIO USB Audio Class 2 Driver" and enable the bridge. In effect, the ASIO bridge acts like a proxy between the player software and the ASIO driver. Make sure you set your audio widget to operate in UAC2 mode.
You don't need to use the ASIO Bridge if your player software has ASIO support (via a plugin, such as foobar2000 or JRiver). You also don't need this if you're running the audio widget in UAC1 mode.
Note that when you are using the ASIO Bridge, it will block other programs from accessing the device.
Can you use this as a multichannel driver for listening to surround tracks with Windows Media Center/Player, Arcsoft TMT, MPC Home Cinema, or VLC?
Sent from my Nexus 7 using Tapatalk
Old 2nd May 2014, 03:37 PM   #2312
linuxworks is offline linuxworks  United States
linuxworks's Avatar
if you downmix the 5.1 (etc) output to linear pcm spdif, yes.
I 'watch movies' all the time by having the multichannel stuff be mapped to stereo downmix.
if you are asking if the AW can deal with dts/dd5.1 directly, the answer is no.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 2nd May 2014, 03:58 PM   #2313
I'm not asking if AW can deal with dts/dd5.1 and am not very interested in always needing to downmix to stereo. When I rip my Blu-rays to MKV containers, I usually have the DTS-HD MA or Dolby TrueHD 5.1/7.1 tracks encoded to FLAC. I understand the AW is limited to 2 channels, but was just wondering if this ASIO bridge would work in a multichannel environment with different hardware. I also wonder if there would be any issues with audio/video synchronization because of additional audio latency when you use this ASIO bridge.
Old 2nd May 2014, 05:59 PM   #2314
linuxworks's Avatar
let me see if I understand: you are asking if you can run several AW's on a single pc and group the pairs of channels into the 5.1/7.1 matrix, so that you can have full multichannel surround support using discrete rca line-outs from the series of AW's?
if that's the question, maybe someone at the driver level can answer it. I have doubts this would work but its more about the driver than the hardware, so I cant help here.
Old 2nd May 2014, 06:17 PM   #2315
amb is online now amb  United States
amb's Avatar
The ASIO Bridge software appears to be multi-channel aware, its control panel has buttons that let you enable/disable up to 8 channels. I don't think you could use multiple audio widgets in that environment, however. You'll need sound hardware that also does multi-channel.
Old 2nd May 2014, 06:21 PM   #2316
linuxworks's Avatar
I read something, a while ago, about using pairs of stereo cards (on linux) to get a discrete 5.1 output without using a surround-capable single sound card. of course, windows would be entirely different.
there was also talk of using hdmi multichannel output as a way to get concurrent discrete outputs, separate from 'surround'.
none of this is easy or standard, though. probably an uphill battle to get any of that multichannel stuff working on non-dd/dts style cards.
Old 2nd May 2014, 08:58 PM   #2317
borges is offline borges  Norway
Short answer: No more than stereo. The MCU is limited in terms of serial interfaces which can send I2S data to DAC chips.
Even if the drivers allowed you to, using multiple asynchronous USB DACs on the same computer, on the same composite audio stream, would probably be a bit of a hassle.
By the way, what does the movie player do when the DAC is asynchronous and requests audio sample rate adjustments from the Host?
BÝrge
Old 19th October 2014, 06:57 PM   #2318
RA3PKJ is offline RA3PKJ  Russian Federation
Hi!
Sorry if offtopic.
Metallic noice with SDR-Widget.
Windows 7-32 and Windows 8-64;
PowerSDR - different versions (it's SDR program);
sdr-widget-2012-10-22.elf;
AWSetup_20130211.exe;
UAC2-audio mode;
In 48/96/192 kHz.
Old 2nd November 2014, 09:20 AM   #2319
LSF is offline LSF
Hi people.
I own the Henry Audio DAC but I'm not able to run it as UAC2 mode using foobar2000.
I've installed ASIO drivers and Audio Widget. OS is win7 and the DAC is now set in UAC2 (red light). I'm trying to play ISO SACD files but I don't get any sound in the speakers.
Using UAC1 mode the DAC works fine with f2k, but I'd like to check UAC2 and try to know the benefits you can get.
I don't know what I'm doing wrong. All your opinions are welcome.
Please, be patient because I'm a beginner on this.
Thanks.
Old 2nd November 2014, 06:06 PM   #2320
LSF is offline LSF
As I am not able to run the dac in uac2 mode I have spent the day testing several iso-sacd and flac files on uac1. As a result, I've reported clicks, pops and stutter using asio with win7.
Any idea what's happening? I've tried all settings but no changes at all.
Thanks.
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2017 diyAudio
