Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 28th November 2013, 04:18 PM   #2271
JANEK555 is offline JANEK555  Slovakia
Default widget problem
hi guys, i have one small problem with widet, it seems to be working. flashing fimrmware was succesfull and after flashing is possible to fing widget in foobar and is possible play with widget but ..... when i disconnect widget from usb and after i connect it again widges is recognized as a AT32UC3 device in dev. manager is possible that fuses are wrong? i flashed 4 types of fw and it is the same situation..... all firmwares works but when i unplug dedget it is recognized as a AT32... not as a audio device please help me
Old 9th January 2014, 03:29 AM   #2272
linuxworks is offline linuxworks  United States
linuxworks's Avatar
this thread has been quite for a while, now.
just checking in to see the status of the firmware. is it considered 'done' now? is it free of all metallic sounds, at this point?
My Photostream:http://www.flickr.com/photos/linux-works/
Old 9th January 2014, 07:41 AM   #2273
amb is offline amb  United States
amb's Avatar
Is any software project ever truly "done"?
Old 9th January 2014, 02:04 PM   #2274
Dendri is offline Dendri  Italy
new firmware see
https://groups.google.com/forum/#!to...et/vnTWBsf-m00
Old 9th January 2014, 02:06 PM   #2275
Old 10th January 2014, 02:29 PM   #2276
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
when it comes to software/firmware, 'done' would be a synonym for 'dead'. Quite the contrary: the project is alive and healthy. Firmware updates with improvements, bug fixes, etc are still coming out every now and then.
My old AB-1.1 have been (and is still) working flawlessly ever since for me, though some nice improvement have come with later versions of the firmware.
On some (other) system/software combinations some problems have been occasionally reported. AFAIK, all of the known problems should have been fixed by the latest release:
https://github.com/borgestrand/widget_binaries
https://github.com/borgestrand/widget_binaries/blob/master/audio-widget-20131208clean_RC.elf
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 12th January 2014, 11:25 AM   #2277
borges is offline borges  Norway
There are few things on the functional todo list at the moment.
Adding DSD functionality has been discussed on the mailing list. I can help out, but I'd prefer to not be the guy who dives down deep into the AVR32 serial port and DMA code.
The revision numbering scheme could also improve. At the moment the firmware doesn't really know which version it is is. However, the .elf files are named quite clearly.
BÝrge
Old 13th January 2014, 06:47 AM   #2278
amb's Avatar
That would be me! It would really be a great feature to have, DSD over USB is all the rage now. The open standard for DSD over USB looks straightforward and ought to be easy to implement.
DoP open Standard | DSD-Guide.com
So who would be the most familiar with that code to lend a hand?
Old 20th January 2014, 08:39 PM   #2279
gabita is offline gabita  Romania
Hello I have the qnktc for 1 year and a few months, no problems on macbook pro, i made some little improvements: used an external Psu with LT1763 regulator, silver usb cable. I am wondering if there is any chance to add a software volume control? (in system preferences it says that "The selected device has no output control". Sometimes I am listening music with Amarra, and navigate on web with safari and some pages have flash player with the volume set on high and it's annoying
Old 7th March 2014, 09:30 PM   #2280
Hi guys,
the USB DAC has been gathering a bit of a following lately :-) The latest review is here: QNKTC AB-1.2 | The Ear
BÝrge
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 07:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 03:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 08:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 11:24 PM
Copyright ©1999-2017 diyAudio
