Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 11th November 2013, 12:11 PM   #2261
mistaspeedy is offline mistaspeedy
Default Changing capacitors
Hi guys!
I want to change some capacitors to improve sound quality, but want to make sure I've gotten everything right. There has been a board revision since Unixman gave a comment, so I want to make sure it still all applies to this board.
Unixman recommended: "See previous posts. Replace all of the 5 OsCon el. capacitors, plus add some of the "missing" (optional) ones: C15, C21, C31, C32, C33, C35 and C36/C37. "
I assume the 5 capacitors in red need to be replaced.
The ones marked in green are the optional ones that have been mentioned.
I could not find the optional 'C15'.
http://i.imgur.com/PBJGZXK.jpg
I'll go with the 6.3V silmic II, 220uF for all the 7 green and 5 red capacitors.
I'm also curious about changing out the capacitors marked in blue, but will leave this for another time. The RCA terminals will be changed too.
Whole board: http://i.imgur.com/uzBc0jD.jpg
By the way, the output resistors have been changed to Dale resistors (by a friend of mine) as you can see.
Old 11th November 2013, 04:55 PM   #2262
linuxworks is offline linuxworks  United States
linuxworks's Avatar
Originally Posted by Mjjg View Post
I haven't tested it yet myself, but seems like someone got raspyfi working on a BBB:
BeagleBone Black as an MPD server
I've been trying to get my BBB to work with the audio widget in uac2 mode. its not there yet (some periodic clicking every few seconds). when I use a uac1 spdif dongle (or the AW in uac1 mode) things are fine.
I'm using ubuntu on the BBB with latest updates.
I don't even use high res audio; just redbook audio and uac2 mode on the bone causes the regular clicking on left/right channels.
any hints on what could be tuned to get this to work properly?
(fwiw, files are on a nas over a wired network using nfs).
My Photostream:http://www.flickr.com/photos/linux-works/
Old 15th November 2013, 03:18 PM   #2263
linuxworks's Avatar
I got myself a hiface (vers 2) to try out for high res audio. on the beagle, its a lot better than the AW but still has some buffering or drop-out issues. not a regular clicking anymore but random drop-outs on 24/96 audio. on redbook or mp3 audio, things are fine.
it could just be that the beagle is underpowered or maybe the UAC2 code is not working well for the ARM cpu type.
so far, though, the BBB is not working out well for music playback. I have not tried my rasp-pi board but my understanding was that the BBB was the better designed system of the two ARM boards (and the pie has a known design flaw on its usb system which seems like a show-stopper).
it looks like I'll have to continue to use mini-itx systems for high quality music playback. the ARM little boards are not powerful enough (oddly, 1ghz; but the system, itself, does not even hold a candle to 'lowly atom cpus' on itx boards).
Old 15th November 2013, 04:56 PM   #2264
Mjjg is offline Mjjg  Sweden
I just made an interesting observation. I've had my R-Pi running as a music player for quite some time now with the AB-1.2, playing music from both an NFS mount and spotify.
Spotify has worked great, but uncompressed files over NFS has been a bit problematic, with intermittent clicks and dropouts.
Today, just for convenience, I tried hooking it up over WIFI instead of LAN. Mosly because I only have one LAN cable routed to that part of my flat and I have an XBMC box there that also needs a connection. Anyways, I expected NFS playback to be completely unusable with WIFI. But to my surprise, it worked much better. It's much more responsive and there are no clicks or dropouts.
I guess the WIFI connection has different buffer sizes compared to the wired interface, and that this is what makes the difference. I have however tried different buffer settings for the wired interface before (both larger and smaller), but it made no difference. So I can't say at this stage why WIFI works better.
So if you're having issues like the ones I had, try switching to WIFI. It might work.
Old 15th November 2013, 08:33 PM   #2265
scopeboy is offline scopeboy  Scotland
Hmm. What Linux distro are you running on the Beaglebone, linuxworks? Just so I know to avoid that one.
I have the Audio Widget running pretty well on the Raspberry Pi. Haven't tried it on the BBB yet. The Pi developers have put a lot of effort into improving USB audio performance lately. I definitely recommend the latest kernel and firmware to give it a fair trial. I actually got better results with the new "FIQ fix" disabled.
"Sadly, audio is like that. It is about the only branch of electronic engineering where lack of knowledge is regarded as a more advanced form of wisdom." http://scopeboy.com/amps
Old 15th November 2013, 10:51 PM   #2266
linuxworks's Avatar
I'm using the latest supported ubuntu on the beagle-black. installed to sd-card not to internal flash.
network is gig-e wired thru 2 switches and onto a dedicated NAS box (using 1 single drive in JBOD mode).
if I use my i3 system, no problems. using an atom n2800 board, still no problem. high res 24/96 audio works flawless on the hiFace and mostly flawless on the AW (slight metallic noises every so often, but its been this way for a long time now and its been months since I last did an upgrade).
strange that the wifi is working better for you. sounds backwards to me
if I can locate my rpi board, I'll give that a try; but right now all I have are regular x86 pc's and the BBB board.
I'll try wifi when I get home today, on the BBB. but wired ethernet certainly should work better, not worse
Old 16th November 2013, 02:14 PM   #2267
Sounds backwards to me too, but I've been running wireless for two days now and not a single hitch. Maybe there's some bug in the LAN interface on the Pi. Either way, it works for me, so give it a try.
Old 16th November 2013, 02:42 PM   #2268
linuxworks's Avatar
the pi's usb is a weak spot and both wifi and wired ethernet go thru usb.
on the bone, though, ethernet does not go thru usb and its usb is supposed to be 'ok'.
this is why I wanted to try the bone. its supposed to be the better design (and implementation) of those 2 boards.
Old 17th November 2013, 02:11 PM   #2269
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
it's not just a board revision... it's an almost completely different product, using a different DAC chip. Also the caps installed by default are of different types, thus my suggestions for the old version cannot be applied to AB1.2 (at least, not "as-is").
You may have a look for a discussion on the subject about AB1.2 here: "Async USB2 - SDR/Audio-Widget collaborative project".
See also here: "QNKTC AB1.2 Dac e preamplificatore valvolare".
(both sites are Italian - try using an automatic translator...).
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 17th November 2013, 03:33 PM   #2270
Unixman, thank you for the information and pointing me in the right direction!
I'll look through those other threads.
If I do end up making any modifications, I will post my experiences here
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
