Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 26th October 2013, 10:44 PM   #2241
linuxworks is offline linuxworks  United States
linuxworks's Avatar
you can build it into the kernel yourself. a friend (who does android devel work) is going to try doing this and I'll report back if we are successful. you need to be rooted to replace the kernel - and its not trivial to do this - but I think it is possible to add usb audio support at some android phones, at least.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 27th October 2013, 05:08 AM   #2242
hc_TK is offline hc_TK  Norway
Originally Posted by UnixMan View Post
Unfortunately, AFAIK Android does not include support for USB audio devices. :-(
Well, yes it can
I use my rooted nexus 7 pad with android 4.2, together with a Hegel hd2 dac.
Use this combination in my car!
Would like to compare these two dacs
/////Alpine, Peerless, Stinger
Old 27th October 2013, 07:42 AM   #2243
Originally Posted by hc_TK View Post
Well, yes it can
Didnt see linuxworks, post.
But yes, as he sais.
It have to be rotted with a custom kernel, but this allows you to tap the digital signal directly from the pad.
And with a asynchronous dac, it sound awsome!
But if I understand it correctly, it depends on the DAC chip if it is compatible with the Pad.
Old 28th October 2013, 09:29 AM   #2244
1audio is offline 1audio  United States
It works with a stock SG4 or Note 2 and some other Android devices. Android does not support 24 bit audio or higher sample rates yet. You need hardware support for it as well since the phone needs to be in host mode and not all hardware supports this (like this phone).
Sent from my myTouch_4G_Slide using Tapatalk 2
Demian Martin
Product Design Services
Old 30th October 2013, 09:54 PM   #2245
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Is there a way to use something like this to read a USB thumb drive to drive a DAC? Thanks.
Old 31st October 2013, 02:49 PM   #2246
If you stick a PC between the stick and the USB DAC. You need a lot of stuff (software/hardware) to read and ttranslate the data on a usb stick into I2S for a DAC.
Demian Martin
Old 31st October 2013, 07:45 PM   #2247
DDriver is offline DDriver  Ukraine
Send a message via AIM to DDriver Send a message via MSN to DDriver Send a message via Yahoo to DDriver
Friends, where I can read a full description of the project, how do I get it?
Old 31st October 2013, 09:18 PM   #2248
Here: Quantization Noise Killed The Cat
There have been a lot of details discussed but Borge has the latest info on his site.
Demian Martin
Old 1st November 2013, 12:20 PM   #2249
scopeboy is offline scopeboy  Scotland
I've finally got round to hooking up the WM8804, but I can't find the schematic for Borge's AB-1.12 that showed how to hook it up! It seems to be gone from his site.
I can figure out the I2S connections, but I seem to remember a RESET line that went to some pin on the USB-I2S module. Can anyone help?
"Sadly, audio is like that. It is about the only branch of electronic engineering where lack of knowledge is regarded as a more advanced form of wisdom." http://scopeboy.com/amps
Old 1st November 2013, 02:10 PM   #2250
MrSlim is offline MrSlim  Canada
Start with something like a BeagleBone Black.
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
