Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 8th December 2012, 06:22 PM   #1961
linuxworks is offline linuxworks  United States
linuxworks's Avatar
I just heard metal noise on an 88k file while skipping forward to the start of another 88k file. have not heard the noise in normal 44k sources, though. this is with mpd (the only thing I use these days) on linux using the latest-1 version.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 8th December 2012, 06:45 PM   #1962
borges is offline borges  Norway
Are you able to replicate the result with last-1 ('6) and last ('7) firmware?
BÝrge
Old 8th December 2012, 06:55 PM   #1963
linuxworks's Avatar
I have not tried the 07 since it would not be optimal for linux. I was hoping the 06 would be my last update for a while
Old 8th December 2012, 06:58 PM   #1964
Fair enough! I'm still trying to understand more and more about the USB Audio protocol, and at the same time make the firmware as stable as possible on all platforms.
BÝrge
Old 8th December 2012, 07:06 PM   #1965
dhbiker is offline dhbiker  Slovenia
88 and 96 ouch on 07 FW with linux (metallic noise)
06 FW seems to be the closest one yet for linux (in my case)
Old 8th December 2012, 07:29 PM   #1966
Yes, the features in '06 need to be there for Linux. I'm curious whether or not what's good for Linux is bad for Mac.
Thanks for doing the test.
BÝrge
Old 9th December 2012, 10:19 PM   #1967
oneoclock is offline oneoclock  Europe
oneoclock's Avatar
Originally Posted by borges View Post
I assume that's with the '07 firmware? When you say BAD, what exactly is happening?
BÝrge
Yes, 07 firmware: awx_20121207_Mac_8896.elf
Bad is two segudos of music, noise and then silence.
Old 11th December 2012, 02:35 AM   #1968
zumbik is offline zumbik  Europe
Hi, the last days I stayed in the frozen forest. Without computer and network.
Zumbik, just to check: did you change f2k to DirectSound playback for UAC1? Nikolay's ASIO driver doesn't support UAC1 on Windows. This is the first report of any kind of UAC1 failing on Windows, so I'm curious. Also, could you explain what goes wrong on UAC2/192/Linux?
BÝrge
So, I have a clean install of win7 64bit, fresh install of drivers AWSetup_20121004.exe and AB1.2 in UAC1 mode.
Foobar2k preferences for UAC1:
and widgetcontrol
I tested a lot of different flac files and always i have the same symptom: slight interruptions and sometimes metalic sounds.
This is my first UAC1 test from September 2012on win7. First time I see such a problem too.
In the case of 192 on linux:
EDIT: (192 in UAC2on linux)
I tested 30 files, all of them 192.
80 percent of them working badly. How, You must see this movie.
On windows7 in UAC2 mode all this files working corectly.
Tested with pulseaudio and without, always the same problem like on movie.
Old 11th December 2012, 02:45 AM   #1969
qusp is offline qusp  Australia
qusp's Avatar
UAC1 does not have the bandwidth for 192kHz, max is 96kHz
Old 11th December 2012, 02:47 AM   #1970
Sorry, 192 i UAC2 mode.
Zumbik
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 07:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 03:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 08:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 11:24 PM
Copyright ©1999-2017 diyAudio
