Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 6th December 2012, 09:23 PM   #1941
dhbiker is offline dhbiker  Slovenia
seems like it fixed my problems.. but i'll wait and see if it shows up later
Old 6th December 2012, 09:23 PM   #1942
borges is offline borges  Norway
Don't know why it gets so big. I build with Cygwin.
Old 6th December 2012, 09:24 PM   #1943
Which were?...
Old 6th December 2012, 09:25 PM   #1944
UAC2 and those annoying metallic sounds which last 1-2secs on linux
Old 7th December 2012, 12:08 AM   #1945
1audio is offline 1audio  United States
Borge-
What is required to build the firmware in Linux? Do you need a GUI to do it?
Demian
Demian Martin
Product Design Services
Old 7th December 2012, 11:29 AM   #1946
oneoclock is offline oneoclock  Europe
oneoclock's Avatar
I tried AB1.2 new firmware in MAC OSX 10.8.2.
UAC1:
44 Bad.
48 OK.
UAC2:
44 OK
48 OK
88 Bad.
96 Bad.
132 Bad
144 Bad
176 OK
192 OK
Old 7th December 2012, 02:16 PM   #1947
Good to know! Thanks. The 132 and 144 cases aren't really supported. I think there were some simplifications done in the USB enumeration which makes them come up.
I'll try to add some tweaks and see if that helps. It'll be a bit like hunting with a shot gun in the dark because I don't have a Mac :-)
BÝrge
UAC1:
44 Bad.
48 OK.
UAC2:
44 OK
48 OK
88 Bad.
96 Bad.
132 Bad
144 Bad
176 OK
192 OK
Old 7th December 2012, 02:25 PM   #1948
Originally Posted by 1audio View Post
Borge-
No GUI!
You'll need a Toolchain from Atmel. Typically something like Atmel AVR Toolchain 3.4.1 for Linux- Atmel Corporation
Atmel keep updating those the whole time... If you look at the script make-widget (at least in the audio-widget* branches) you'll see how the compiler is instructed as to where to find the toolchain. The toolchain has slightly different locations with and without the GUI installed.
I personally use the GUI in Windows to navigate the project but I build with "make clean audio-widget" in Cygwin.
BÝrge
Old 7th December 2012, 02:31 PM   #1949
Could you check if this helps for MAC at 88.2 and 96?
awx_20121207_Mac_8896.elf
Source code is pushed to audio-widget-experimental branch.
BÝrge
UAC1:
44 Bad.
48 OK.
UAC2:
44 OK
48 OK
88 Bad.
96 Bad.
132 Bad
144 Bad
176 OK
192 OK
Old 7th December 2012, 06:45 PM   #1950
New firmware- I have tried the normal sample rates (44.1, 48,88.2,96,176.4,192) on Linux 3.6.6 and mpd 0.17.2 with no glitches burps or any other sign of distress. All working fine.
Interesting observation on difference between Linux driver and windows/OSX driver-
for Windows/Mac:
1) Set sample rate
2) set interface
For Linux it is reversed:
1) set interface
2) set sample rate
Both are legit but can have a big impact on how the device responds if its not prepared to handle the differences. Also Linux turns around much faster than the other drivers.
Demian Martin
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
