Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 6th December 2012, 09:27 PM   #1931
borges is offline borges  Norway
Hi guys,
I found a bug in the feedback code I wrote back in October. Even with the bug in, stability seems to be good. Still, what I believe to be improved code is checked into branch audio-widget-experimental and compiled into awx_20121206.elf
Please help out with testing the UAC2 playback on Linux, Mac and Windows. My own tests on Win7-64 are good.
Also, there have been some reports that UAC1 was noisy on Mac OS X. If you can help out with UAC1 tests of the newest updates, that would be very good. I hope recent changes for Macs haven't broken UAC1 support elsewhere. I don't have a Mac to test with here. (See below for details.)
The UAC2 code uses something like a 4-point P-regulator. (The October version had a bug which actually turned it into a 3-point P-regulator with asymmetrical thresholds.) I found the bug and added even more stability to the regulator using a simulator in Octave. Let me know if anyone's interested in the source code for that :-)
Before October the UAC2 code used a 2-point thermostat regulator. The UAC1 code in this update also uses a 2-point thermostat regulator. If there are observations of rarely-occuring mid-music noise in UAC1 I can port the 4-point P-regulator to UAC1. But I don't think I'll try to fix that before it turns out to be a problem.
BÝrge
Old 6th December 2012, 09:48 PM   #1932
1audio is offline 1audio  United States
Originally Posted by Catal View Post
It's the filter setting in the widget control software.
As I said to Borges, I know that this selection is "only" possible for the PCM5102 dac, ... cause AK4430 datasheet says clearly that only fir filter can be used, ... that I should hear no difference between these two options.
Frank
I can't find a reference to filtering in the AK4430 datasheet. You get what it has, only.
I don't think that gpio goes anywhere on the AB1.2. Maybe Borge can enlighten us?
Demian Martin
Product Design Services
Old 6th December 2012, 09:50 PM   #1933
Do I need to use Widget control to flash the firmware now? I had become used to the command line process. I'll try the new firmware over the next few days.
Demian Martin
Old 6th December 2012, 09:51 PM   #1934
That's right Demian,
that GPIO line is not used in the AB-1.2.
BÝrge
Old 6th December 2012, 09:58 PM   #1935
Widget Control doesn't do any flashing. You'll need the command line from Atmel's Flip program. Full description in the Readme file in my signature.
BÝrge
Old 6th December 2012, 09:59 PM   #1936
linuxworks is offline linuxworks  United States
linuxworks's Avatar
I just upgraded mine to the latest fw using cli on win7. worked fine. (whew!)
I see this on linux, now:
Code:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: AB12 [QNKTC USB DAC AB-1.2], device 0: USB Audio [USB Audio]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
this changed the naming in my alsa state file:
Code:
state.AB12 {
        control.1 {
                iface MIXER
                name 'Clock 2 Playback Switch'
                value.0 true
                value.1 true
                comment {
                        access 'read write'
                        type BOOLEAN
                        count 2
and it used to be
Code:
state.DG8SAQI2C {
this caused me to have to re-edit my alsa state file (I do weird things with it, so I have to, lol) but was there a reason the name had to change?
My Photostream:http://www.flickr.com/photos/linux-works/
Old 6th December 2012, 10:02 PM   #1937
The name change happened with the change to unique USB VID/PID codes. Now George and I use different "product name" strings.
BÝrge
Old 6th December 2012, 10:06 PM   #1938
linuxworks's Avatar
will this new one be stable for a while? or even forever?
Old 6th December 2012, 10:07 PM   #1939
If it tests good on all platforms, yes!
BÝrge
Old 6th December 2012, 10:17 PM   #1940
linuxworks's Avatar
btw, the elf file size grew dramatically. that almost threw a red flag to me, before I started the download to the device.
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 07:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 03:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 08:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 11:24 PM
