Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 22nd May 2012, 08:52 AM   #1541
gioz is offline gioz  Italy
gioz's Avatar
Hi Borges, the USB to I2S module with pre mounted clock are ready to use "out of the box" for connection with (for example) buffalo 2 dac??
Thank
Old 22nd May 2012, 09:36 AM   #1542
borges is offline borges  Norway
Hi Gioz,
Here is an example of someone who has mated it with a Buffalo DAC. He has used the one with XOs mounted on the board. I don't know if the Buffalo is able to produce 11.2896 / 12.288MHz clocks.
Innmat.. Hva du vil!!! - Side 82
BÝrge
Old 22nd May 2012, 11:29 AM   #1543
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
I thought that that board could be used as-is without any modification for DAC with ASRC input such as the stock BII/BIII. Isn't it like that?
doesn't the USB-I2S module (version with on-board clocks pre-mounted) have its own divider & clock switch logic on board?
unfortunately it does require registration to see attachments/images.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 22nd May 2012, 11:33 AM   #1544
It does, yes. The divider is there. The switch logic is implemented by enabling one XO at the time and shorting their outputs.
So it seems, yes. I don't own a Buffalo DAC. There is some talk about an 80MHz clock. If that is the case, and the MCLK from the XO-equipped module is not used, the DAC chips are operating asynchronous to the sample rate of the music. All my experience is with synchronous systems, but that doesn't mean async is bad.
BÝrge
Old 22nd May 2012, 01:20 PM   #1545
gioz's Avatar
Thank ;-)
Old 22nd May 2012, 01:45 PM   #1546
UnixMan's Avatar
yes. IIRC newer versions have 100MHz clock. According to many (including the chip designer), the higher the clock the better it works (and sounds). This is true also in synchronous mode: for best performance you'd need two ~90MHz clocks.
(and it is true for all Sabre DACs, including the ES9023. Unfortunately, the ~20MHz clock of the AB-1.1 gives a bad performance penalty, specially with source material at higher sample rates).
Old 23rd May 2012, 04:10 PM   #1547
gioz's Avatar
OK just ordered ;-)
Old 24th May 2012, 08:32 AM   #1548
ElEsido is offline ElEsido  Switzerland
Originally Posted by Remrk View Post
some info on how to inject a external PSU
You can start here and here. Consider this and that from Guilio; he might be able to help further.
Please keep us posted and take some pictures of what you do. Also I for one am very interested in the effects of your capacitor changes, how would you describe the effects on the sound?
Old 24th May 2012, 08:49 AM   #1549
UnixMan's Avatar
if you have set a non-default number of post per page those links will not work. If you have this problem, try removing the page number from the URL, like this:
post2840845
post2841397
post2958268
post2960104
(the system will redirect you automatically to the right page).
Old 24th May 2012, 09:03 AM   #1550
Thanks!
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2017 diyAudio
