Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Old 6th February 2012, 08:02 PM   #1081
borges is offline borges  Norway
Hi Turbon,
the AB-1.12 will be a naked board for analog prototyping. In order to do anything with it you'll have to populate it with whatever feature you wish to prototype. Then you need to plug in an existing USB-I2S module.
The AB-1.12 will fit in the same enclosure as the AB-1.1. The board is only an add-on to the AB-1.1 with features not yet tested.
The PCM5102 is already designed in. Right now I'm working on the new suggested regulators. It's hard to tell exactly when I'll be done with it.
BÝrge
Old 6th February 2012, 08:32 PM   #1082
Turbon is offline Turbon  Sweden
Turbon's Avatar
Originally Posted by borges View Post
Hi Turbon,
BÝrge
OK, thanks BŲrge!
Looking forward to the naked board... Are the DAC's pin compatible or what kind of solution do you have in mind? I might have a different interpretation of the meaning of an "add-on" - should I keep the AB-1.1 and wire an add on board in the old DAC's place or will the new board replace the whole AB-1.1 board? What about a new DAC - should I then replace the AB-1.2 with the AB-1.3 board if a new DAC is invited to the widget world? Shurely there must be a way to disminish the cost by the way of an modularized approach.
Brgds
Old 6th February 2012, 08:36 PM   #1083
Yes, cost is reduced because you recycle the module and the box you already bought from me :-)
The AB-1.12 will only be an analog board. Since the two XOs are custom components I'll probably ship them with the naked board so that you don't have to strip components off what you already have. The remaining components should be easily obtained and depend on what you want to implement on the proto.
BÝrge
Old 7th February 2012, 04:04 AM   #1084
Turbon's Avatar
Default The DAC BŲrge - the DAC?
Will it be on its own board on AB-1.2?
As I see it 1.2 should be the splitpoint in time where the AB becomes really analog carving out the DAC to a board to itself.
Brgds
Old 10th February 2012, 06:55 AM   #1085
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Suddenly, I'm having those already mentioned rate-change issues as well.
This is my stream0 when mpd changes from a 16/44.1 to a 24/96 wav-file:
Code:
www.obdev.at DG8SAQ-I2C at usb-0000:00:13.2-2, high speed : USB Audio
Playback:
  Status: Running
    Interface = 2
    Altset = 1
    URBs = 8 [ 8 8 8 8 8 8 8 8 ]
    Packet Size = 392
    Momentary freq = 181492 Hz (0x16.afc0)
    Feedback Format = 16.16
  Interface 2
    Altset 1
    Format: S32_LE
    Channels: 2
    Endpoint: 2 OUT (ASYNC)
    Rates: 44100, 88200, 132300, 176400, 48000, 96000, 144000, 192000
    Data packet interval: 250 us
Is there a comprehensive how-to how to deal with firmware updates? Are they possible on a linux shell (x-less system) or must/should I plug the widget in a windows machine?
RŁdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 10th February 2012, 08:00 AM   #1087
Onvinyl's Avatar
Thanks Alex, I'll wade through this.
How can I read-out the firmware version?
lsusb gives e.g.
Code:
  iManufacturer           1 www.obdev.at
  iProduct                2 DG8SAQ-I2C
  iSerial                 3 1.0.0.0.0.0.A
RŁdiger
Old 10th February 2012, 10:37 AM   #1088
Default Regulator Update
Here is a draft sch and layout for the regulator which has been discussed here lately. Any comments?
I plan to put 3 such regulators on the AB-1.12 prototype board. The regulators will not be connected to other circuitry. It will be easy to patch them into points of load at the two XOs and at the DAC.
BÝrge
Old 10th February 2012, 10:54 AM   #1089
Onvinyl's Avatar
Hi BÝrge,
are these regs intended to run from dedicated PSUs or are they intermediate stages between usb-power and DAC/XO?
RŁdiger
Old 10th February 2012, 10:56 AM   #1090
Both! The digital parts run from the 3.3V LDO on the module. That will include the MCLK divider whos only purpose is to synchronize the MCU.
BÝrge
Open-source USB interface: Audio WidgetHide this!Advertise here!
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2017 diyAudio
