Open-source USB interface: Audio Widget - Page 222 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th June 2013, 02:25 PM   #2211
borges is offline borges  Norway
Well, I did edit the UAC1 USB descriptors heavily. If you can run it past some sort of USB descriptor error reporting engine, that would be good.
I've been testing the firmware on OS X and XP all day. It's been stable the whole time except one missed feedback event in XP. So tonight I'll port the 2-level feedback algorithm from the UAC2 code. XP accepts the feedback data it is getting, and I see very little correction activity for the sample rate (which is good).
BÝrge
Old 5th June 2013, 05:54 PM   #2212
Here is the result of a large UAC1 cleanup. Please test on all OSes.
awx_20130605.zip
The major changes are:
- IN endpoint removed (OS X playback confused by a dead microphone)
- Endpoint tweaking
- FB_rate_delta=64 (gentler response by FB state machine)
- Multi-level FB algorithm ported form UAC2
- Easily turn debugging on and off in conf_usb.h
It's tested on Win7-64, XP and OS X. Playback at 44.1 and 48 are stable. Audio-Widget and HID work.
BÝrge
Old 6th June 2013, 05:18 PM   #2213
dhbiker is offline dhbiker  Slovenia
what's the git or svn for your code (lost the info) ?
Old 6th June 2013, 06:24 PM   #2214
Follow my signature to the readme file. It's all summarized there. The new code is in branch audio-widget-experimental.
BÝrge
Old 12th June 2013, 07:34 AM   #2215
UAC1 seems to work fine but UAC2 seems to have problems... here is the dmesg output:
[ 1244.401486] usb 1-6: New USB device found, idVendor=16d0, idProduct=075d
[ 1244.401490] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1244.401492] usb 1-6: Product: QNKTC USB DAC AB-1.2
[ 1244.401494] usb 1-6: Manufacturer: Audio-Widget
[ 1244.401495] usb 1-6: SerialNumber: 1.0.0.0.0.0.A
[ 1244.407045] input: Audio-Widget QNKTC USB DAC AB-1.2 as /devices/pci0000:00/0000:00:0b.1/usb1/1-6/1-6:1.3/input/input7
[ 1244.407153] hid-generic 0003:16D0:075D.0003: input,hidraw0: USB HID v1.11 Device [Audio-Widget QNKTC USB DAC AB-1.2] on usb-0000:00:0b.1-6/input3
[ 1414.334410] cannot submit urb (err = -18)
[ 1414.334421] cannot submit urb (err = -18)
[ 1414.334424] cannot submit urb (err = -18)
[ 1414.334429] cannot submit urb (err = -18)
after that no app can play a sound
Audio output failed:
The audio device "default" could not be used:
File descriptor in bad state.
unless it's outputing directly to hw:0
hopefully it helps to determine the problem
Old 12th June 2013, 06:42 PM   #2216
Thanks for letting me know. While I focused only on the UAC1 code this time, some UAC2 stuff might have suffered from #defines meant for UAC1. I'll look into it and see what happens.
Do you have the same issues in both the debug and clean builds of the code?
BÝrge
Old 12th June 2013, 07:01 PM   #2217
yup pretty much any FW from AB-1.2 shipping on..
Old 14th June 2013, 08:19 PM   #2218
I have diffed the code in git going back to January 13th, and I don't think I've found any major show-stoppers in the UAC2 code. In any case, I have built the attached code today and committed to audio-widget-experimental.
In this code I have increased the polling interval on the feedback endpoint on both UAC1 and UAC2. I did see some tendencies in UAC1/Win7-64 that things were going a bit too fast for all polls to be taken, particularly through a hub. It looks better now.
My Linux box (Mint, 3.0.0.0-12 generic) is able to play music quite well using mpd. All frequency transitions on UAC2 work. This computer isn't highly stable at the moment but music seems OK.
BÝrge
Old 30th June 2013, 06:56 PM   #2219
Hope this is right place to post this - I just completed project using WaveIO USB to I2S card to drive North Star 192 DAC via I2S - it works on all frequencies NOT JUST 192 as some people reported. WaveIO is connected via USB to VortexBox 2.2 and using Vortexbox player. Very very sweet and clear sound - USB to I2S is must if you are serious about the sound.
Old 12th July 2013, 10:35 AM   #2220
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
Hi BÝrge,
I have just quickly tried out (both in UAC1 & UAC2) your latest firmwares:
awx_20130605clean.elf
and
audio_widget_20130614debug.elf
functionally, both seems to work fine (Debian GNU/Linux "Wheezy" 32bit, Kernel 3.9-1-686-pae from "Sid").
There seems to be some sound differences between the two firmwares, though (similar both in UAC1 and UAC2 mode). I wonder whether the differences may be due to the "-debug" code or something else (feedback loop?).
Could you provide a "-clean" version of the latest firmware?
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2017 diyAudio
