Open-source USB interface: Audio Widget - Page 220 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th April 2013, 03:28 PM   #2191
1audio is offline 1audio  United States
Originally Posted by cviller View Post
Sorry guys, but I don't see it.
The gnd plane on solder layer (brown polygon Open-source USB interface: Audio Widget) is unbroken all the way from DAC chip to connector and Iout+/Iout- are routed closely together from chip to connector - where is the dipole antenna?
It can be hard to see details on an image like this, especially when you can't be sure of what you can't see. You also do have what seems to be a ground adjacent to one of the traces. If its too close it could unbalance the network, otherwise it seems pretty good.
Demian Martin
Product Design Services
Old 21st April 2013, 03:13 PM   #2192
cviller is offline cviller  Canada
cviller's Avatar
I have made a few changes: ADC connector added, correct SPI pins used, 3.3 V regulators swapped and better clearing of the current out traces.
The polygons on component side are actually psu - is that bad approach in practice? One of the few things I remember from high speed subjects at university was the importance of short signal path for supplies&gnd, as well as the coolness of using the layers to make ultrafast plate capacitors in the pico range...
The first image show gnd layer - brown is AGND and cyan is DGND. Second image show the signal traces and small sections of supplies. Any comments are welcome.
Old 23rd April 2013, 05:29 AM   #2193
It looks like you have done an excellent job of pulling it together. I probably would have given up and gone to a 4 layer PCB but I get lazy.
Demian Martin
Old 23rd April 2013, 05:38 AM   #2194
The Linux Kernel patch created for the CM6631 and the Via chip also got the Audio Widget working without the Linux hack. I posted the patches here Linux Audio the way to go!? for those ready to build kernel modules. Otherwise if you can get a 3.9 Kernel the patch is already in it (or so I hear).
Demian Martin
Old 23rd April 2013, 07:29 AM   #2195
cviller's Avatar
Regarding the ADC connector, I have taken the master clock directly from the isolator, so it is the same ~22MHz (of course with a small delay) used for the DAC master clock. Is that the most optimal clock for the ADC?
Old 23rd April 2013, 02:03 PM   #2196
greggp is offline greggp  United States
Send a message via MSN to greggp
I'd love to see Google add native support for USB Audio Class 2.0 drivers in Android. Then, using my Android phone or tablet, I could play high res files. It would also be great if a desktop version of Android were developed and we could build HTPCs running Android.
If you'd also like USB audio support in Android, go here:
https://code.google.com/p/android/is...stars&id=24614
and vote!
Be sure to click on the star at the bottom of the page to register your vote.
Old 23rd April 2013, 02:18 PM   #2197
I believe the latest Samsung devices (Note2 Tab ??) do support USB audio. I'll test that theory soon.
Demian Martin
Old 23rd April 2013, 03:28 PM   #2198
Is there native USB audio support on Android?
That's what I want.
Old 21st May 2013, 11:37 AM   #2199
borges is offline borges  Norway
100 fresh new AB-1.2s just arrived on my door :-) That means I'm no longer sold out!
BÝrge
Old 25th May 2013, 09:10 AM   #2200
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Just got my QNKTC DAC going Borge. Problem was the set up in JRiver MC.
Very nice DAC I have to say - exceptionally clean sound.
Any chance of an optical interface?
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2017 diyAudio
