Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th February 2013, 03:26 PM   #2121
Originally Posted by Dendri View Post
audio_widget_20121004_AB-1.2 I regret having updated
Not to worry. If all your attempts fail you can still try:
1. flash the firmware with Linux. If you are a Linux user (or can find a friend who is a Linux user), There are experienced Linux users in this thread to guide you to flashing under Linux.
2. If 1 fails, you will need jtag-ice MkII flashing.
Alex
Old 14th February 2013, 12:23 PM   #2122
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
Originally Posted by borges View Post
Do you know if those older MACs support _asynchronous_ UAC1?
Oh! Good question: I don't know.
(not a Mac user myself...).
Maybe some info can be found here: "Technical Note TN2274 - USB Audio on the Mac".
See also: "Asynchronous OUT endpoint with rate feedback?" (it looks like some source code for OS/X have been made available).
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 19th February 2013, 09:42 PM   #2123
starn02 is offline starn02  Italy
An off topic question to Alex and Borges ....
Do you know if the I2C code in the firmware is working?
I'm trying to use it to access an LCD but while the writes are OK the READS are not working in my case ... in detail the addressed chip does not issue the requested ACK after the repeated start in the READ command (and the rest of the waveform is OK ...)
I see that the code is based on Atmel asf 1.6, and I know (having searched a lot on internet) that in that version the TWIM code was buggy .... what about the code in the firmware? Is it the same as in the SDR widget (where I suppose I2C is heavily used?)
Regards.
Old 19th February 2013, 10:15 PM   #2124
Starn02,
The i2c code is identical between sdr-widget and Audio-Widget.
The TWIM library from atmel has been modified for our use. Bugs were fixed and we enabled both ports.
Alex
Old 20th February 2013, 12:11 AM   #2125
tdtsai is offline tdtsai  Taiwan
As I know Mac OSX 10.4.x and later version all can support UAC 1.0 Asynchronous out endpoint.
Old 1st March 2013, 06:25 AM   #2126
dhbiker is offline dhbiker  Slovenia
so.....
my AB-1.2 just failed on me
first two pins on J5 show 0V, J4 also no voltage whatsoever. J2002 and J3002 fluctuate from 1.6 to 1.8V and J3, J8 show no voltage too...
any clues ?
yesterday i disconnected it and today i connected it... NADA
thanks for your reply
Old 1st March 2013, 07:16 AM   #2127
1audio is offline 1audio  United States
First check the cable and the host (and the connectors). The cables and connectors can be pretty fragile. Make sure the port is OK. There are circuit breakers that would give the impression of a high resistance source at the USB host.
Demian Martin
Product Design Services
Old 1st March 2013, 08:33 AM   #2128
good guess on the port... seems like i'll have to replace it with a new one
thank you very much
Old 11th March 2013, 04:22 AM   #2129
The I2S of my DAC shows DATA/LRCK/BCK/MCLK, what's pins on the USB-I2S board I should use to connect to the DAC?
Old 11th March 2013, 10:26 AM   #2130
borges is offline borges  Norway
DATA: DA_SDATA TP58
LRCK: DA_LRCK TP59
BCK: DA_SCLK TP56
MCLK is trickier. The common variety of the USB-I2S module does not supply MCLK. Instead, your DAC board must generate it and send it to the module. (It may be that you have a module with XOs on it. In that case ignore the text below and tap MCLK from TP34.)
1) Provide 11.2896MHz on TP34 and 12.288MHz on TP36.
2) When TP32 (MCLK_P48_N441) is '1', provide 12.288MHz on TP34 and TP36, when TP32 is '0', provide 11.2896MHz on TP34 and TP36. This is how the AB-1.2 is set up.
I'm sure you'd like the XOs to be on the module at this point. BUT: any DAC will perform better when the XOs are close to the converter chip and running off a clean supply under your control. The module does have room for XOs but they run from the same 3.3V supply as the MCU.
Good luck with your DAC design!
Børge
=== AB-1.2 and USB-I2S Module === Audio Widget readme ===
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2013 diyAudio
