| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#2111 |
I've been using my own wm8804/5 chip on the AW for several months now without any problems at all. at all SR's too.
My Photostream:http://www.flickr.com/photos/linux-works/ |
#2112 |
The WM8804 looks even more attractive now that I've searched my chip drawer, I appear to have lost the CS8406s.
'Like the thirteenth chime from a crazy clock which not only in itself fails to command belief but also casts a certain doubt upon the accuracy of the previous twelve strokes.' |
#2113 |
updating the firmware on my ab1.1 was locked, LED interior and exterior off. Removing from the batch command erase f and blankcheck seems to begin to plan,read bootloader1.03 , but then does not complete the program. I use to force a jtag or something? There is a simple project to build it? I'm from Naples. thanks
#2114 |
Hi everybody,
what are the latest news about the high frequency noise issues on windows? Is the firmware unchanged recently? From my side I can tell you that in the last days I've been using the board (a stock 1.1) exclusively with a macbook pro (in UAC2) without a single issue at every sample rate, even for listening sessions during entire afternoons .... Now I'm using an Ipad 1 with the board connected via a powered hub and a "camera connection kit" ... only at 44100, but it sounds wonderful, no problem at all ... My conclusions are that the firmware is Ok, completely OK, and that under windows there are still problems if we don't use the asio driver .... Do other guys confirm this? |
#2115 |
Hi guys,
I have uploaded a new build of the Windows ASIO driver and WidgetControl at: AWSetup_20130211.zip Major updates: 1) Built with libusbK 3.0.5.16 2) Improved Windows 8 support 3) Increased stability for 44.1/88.2/176.4 playback It came about because there was a report of malfunction on a Win8 system. This update works on his computer now, and it installs nicely on my development box (Win7-64). Børge Last edited by borges; 11th February 2013 at 08:08 PM. |
#2116 | |
Hi Starn,
The latest firmware at audio_widget_20130202.elf seems to be stable on all platforms except Mac+UAC1 (which frankly doesn't matter all that much). The Windows ASIO driver (my previous post) has received a little stability fix which wasn't critical, and now makes UAC2 on Windows behave more like it does on Linux and Mac. As before, to use UAC2 on Windows you need the driver, and playback only works from ASIO enabled player software. On UAC1 music is played back with the stock Windows USB audio driver, but if you need the control interface (WidgetControl), or if you don't want driver installation error messages, install the Windows driver even on UAC1. Børge Quote:
#2117 | |
Do you have a multimeter? Could you check if the output from the regulator is 3.3V or 5.0V? (This is TP27, 4th pin from the top near the edge of the AB-1.x.)
Some early units had 5.0V bug which wasn't detected. If your board has this, I'll send you a new module. Børge Quote:
#2118 | ||
#2119 | |
If you have any ideas on why it isn't working on ML, let me know and we can try to fix it there first, then check it out on older Macs. With a Bitscope or similar it's easy to debug the feedback. Børge |
#2120 | |
since the LED always off I'm not sure that enters the program mode . by removing batch command erase f and blankcheck seems to begin to plan, reads from usb and says bootloader1.0.3, prog pass 0x00000 0x1ca8f verify fail at 0x02006 how can I do? With fimware that I put before the metallic sound was not feeling almost never audio_widget_20121004_AB-1.2 I regret having updated hello Borge my bad English comes from google translator |
| Async 192Khz USB - the SDR-Widget collaborative project | SunRa | PC Based | 5 | 26th April 2011 06:38 PM |
| usb audio interface | david12 | Equipment & Tools | 14 | 10th October 2010 02:58 AM |
| Cheap Audio Interface (USB?) to PC | agm2003 | Instruments and Amps | 11 | 16th September 2007 07:48 AM |
| Open call for suggestions on Open Source DIY Audio Design | gfergy | Everything Else | 1 | 15th April 2007 07:33 AM |
| USB Interface Perfect?- Computer Audio | fmak | Digital Source | 3 | 4th December 2004 10:24 PM |
