| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#2101 |
I posted my findings over in the Raspberry Pi thread:
Raspberry Pi -A New DIY'ers Digital Hub? With the config I posted there, as far as I can see it is glitch-free as long as there are no USB1.x devices in the system. But if one is connected, such as a keyboard, it'll cause the occasional pop even if you never press any keys. This means I have to scrap my USB HID user interface. However it is so easy to control from a smartphone or tablet, that I'm questioning whether I needed the UI in the first place.
'Like the thirteenth chime from a crazy clock which not only in itself fails to command belief but also casts a certain doubt upon the accuracy of the previous twelve strokes.' |
#2102 |
The driver source code has been modified for Win+ASIO at 44.1/88.2/176.4 to behave more like UAC2 on Linux and Mac. The updated driver causes fewer sample rate corrections to occur.
Please test on various Windows platforms. If this turns out to be stable and good I'll pack it into an installer as well. For now it's just a new .dll file which goes on top of an existing installation. Download and instructions: http://code.google.com/p/sdr-widget/...e=asiouac2.dll Updated code: https://github.com/nikkov/Win-Widget/tree/master/uaclib Børge Last edited by borges; 22nd January 2013 at 12:33 PM. |
#2103 |
Update: I've done hours and hours of 44.1 testing on Linux, Mac and Win+ASIO. The three now seem to behave very similarly. To stabilize the host the firmware never seems to have to increase or decrease its reported frequency by more than five steps of 64 in the same direction. Normally 2-3 steps are sufficient.
Børge |
#2104 | ||
With which firmware version? audio_widget_20130113.elf or some new experimental one? What about 48/96/192 ?
#2105 |
It's the Windows driver on UAC2. The updated .dll should work with most firmware versions.
The driver used to operate very differently on 44.1*2^n and 48*2^n. On the latter it used to be a lot like Linux and Mac, on the former it required frequent correction. With the modified code all modes look like they do on Linux and Mac. Børge |
#2106 |
Any tips on adding a SPDIF output to the AB-1.2 DAC? I know SPDIF is evil
but I want to build another of these Raspberry Pi things for my other system, and it has digital room correction, so needs a digital input.
#2107 |
Follow my signature and check out the ES9012/18 prototype section :-)
The AB-1.12 / 1.13 prototype boards have SPDIF TX options. The only downside is that you'll have to assemble the analog board yourself. Børge |
#2108 |
Are you happy with the WM8804? I have some CS8406 somewhere, but I'd use the WM8804 if you've already tested it and got good results.
#2109 |
I haven't tested it thoroughly. But it played anything I fed it right out of the box.
Borge |
#2110 |
Cool :-) But before I do that, I ought to try hooking up a separate analog power supply to the AB-1.2 I already have.
Have you tried disabling the charge pump on the AK4430 and feeding it with an external negative supply?
| Async 192Khz USB - the SDR-Widget collaborative project | SunRa | PC Based | 5 | 26th April 2011 06:38 PM |
| usb audio interface | david12 | Equipment & Tools | 14 | 10th October 2010 02:58 AM |
| Cheap Audio Interface (USB?) to PC | agm2003 | Instruments and Amps | 11 | 16th September 2007 07:48 AM |
| Open call for suggestions on Open Source DIY Audio Design | gfergy | Everything Else | 1 | 15th April 2007 07:33 AM |
| USB Interface Perfect?- Computer Audio | fmak | Digital Source | 3 | 4th December 2004 10:24 PM |
