Open-source USB interface: Audio Widget - Page 199 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th December 2012, 09:02 AM   #1981
AFAIK all the commits to audio-widget branch since Aug this were from you Borges :-)
Old 12th December 2012, 09:08 AM   #1982
I'm just trying to help Zumbik to get 192k working under Linux. As I said I have had no problems with 192k and 176.4k music at all and I have been using the audio-widget branch firmware.
(I do have problems on 88.2k (and may be other sampling rates, not tested) with the latest commits using the audio-widget-experimental branch though, EVEN AFTER reverting your removing of the linux fix in a local branch.)
So to remove another variable coming from all your changes in the experimental branch, I thought it would be good to let Zumbik try something not so experimental :-)
Old 12th December 2012, 09:11 AM   #1983
I have found Zumbik's command:
watch -n 1 "cat /proc/asound/card1/stream0"
to be useful so I have just added it to:
watch-card1.sh
in the audio-widget branch :-)
Old 12th December 2012, 09:16 AM   #1984
borges is offline borges  Norway
So your build of audio-widget was without any code changes?
This is why we call the branch experimental :-) I've been toying with a feedback simulator I wrote in Octave and moved the code which did the best job there into the firmware.
BÝrge
Old 12th December 2012, 02:33 PM   #1985
zumbik is offline zumbik  Europe
Hi all,
1) I can live without the 192k for linux ... yet
2) I seriously wonder about construction of the RS232 interface on AB1.2 board. We have a lot os environments. Probably none of us are not aware what's exactly going on inside AB-1.2 when are having problems in the sound. If I understand correctly, rs232 logs should show where the problem is? How can I build environment for tests?
Borges, whether you make HOWTO?
Then my logs will be yours ...
Old 12th December 2012, 02:44 PM   #1986
Hi Zumbik,
if you populate the RS232 amplifier, set your terminal to 57.6kbaud and plug it in, the debug port should come alive!
First of all you'll need a build environment. See Line 621 and onwards in the Readme file in my signature. Then you can start adding debug messages and building your own code.
I believe a single putchar is harmless because the UART is double buffered. But if you output character #2 before the 1st is sent, things start to take more time because the 1st one hasn't yet left the MCU.
BÝrge
Old 12th December 2012, 03:00 PM   #1987
Ok, it looks like black magic, yet ...
I understand that it makes sense and will give us the an explanation of trouble?
Old 12th December 2012, 03:04 PM   #1988
1audio is offline 1audio  United States
Before you launch into changing the code please make sure everything else is working right.
I have a collection of different sample rate files (most from Gimmel) tthat are stored as wave file I can play using aplay. This remove many. Moving parts from the chain. If you have pulseaudio you may need to shut it down to access alsa.
You need recent alsa or a recent Kernel for this to work OK. I am using 3.6.6 but I will migrate to 3.7 soon. 2.6.32 would be the oldest I think.
I have had no problems with any sample rate or transistion with 3.6.6 and mpd.
Sent from my myTouch_4G_Slide using Tapatalk 2
Demian Martin
Product Design Services
Old 12th December 2012, 08:57 PM   #1989
Here is where to get the Gimell test files: Gimell Records - Free Trial Downloads 1
I find them very useful tools.
Demian Martin
Old 13th December 2012, 08:47 AM   #1990
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
no. The ALSA version included in Linux kernel 2.6.32 does not support UAC2 (unless an out-of-three, newer ALSA is used). The first "vanilla" kernel which should work is 2.6.38.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2017 diyAudio
