Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th December 2012, 01:37 PM   #1921
In the audio-widget branch, the latest update adding revised VID/PID into WidgetControl was two months ago. The latest update adding the productid4=0x3e9 into widget-control.c was seven months ago.
It looks like widget-control.c may not be in sync, but I'd leave final analysis to Alex or Borge.
Old 5th December 2012, 03:31 PM   #1922
lm1no2 is offline lm1no2  Norway
I testet about 4 hours on Windows 7 and no problems. The converter works perfectly, especially with external DAC. Any info about new version with galvanic isolation ?
Old 6th December 2012, 09:35 AM   #1923
Catal is offline Catal  Italy
I'm amazed by a change in the Widget Control.
Has someone tried iir filter instead of fir one?
With the AB 1.2 and AK4430 dac it seems to me it improves bass deepness and articulation and trebles become more polite and focused.
Distortion seem to be a lot less.
For me it's a lot better than with fir filter.
Frank
Old 6th December 2012, 10:15 AM   #1924
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
Good to know, thanks.
Though the preferred setting may be subjective and/or depending on the context (remaining of the audio chain, room, recordings, etc). If you have an AB-1.2, don't forget to try both settings to find out... and let us know about your experiences.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 6th December 2012, 01:52 PM   #1925
I've used Fir filter since the beginning.
Then I did some mods:
- two LifePO4 supplies for the Xos
- three crcrc linear supplies and three Salas shunt regulators for 3,3v and 5v
- Mkp bypassed with teflon cap in the LPF filter
- Dale resistors rn55 in the LPF filter
- Dale resistors rn55 in the I2s lines
Sound has improved a lot with IIR filter.
This is my setup:
Headphone____Laptop - Jplay SW - Violectric V200 - Rudistor Chroma MD1 and AKG701.
Speaker____Laptop -Jplay SW - B4 Preamp - Ncc200 Amp dual mono - Audio Physic Brylon - Cabasse Santorin25
Test has be done with classical and jazz.
Frank
Old 6th December 2012, 02:00 PM   #1926
borges is offline borges  Norway
Interesting stuff with the regulators! Do you have schematics to share?
The fir/iir setting shouldn't be doing anything on the AB-1.2. The AK4430 doesn't have a filter selectr input. The functionality was put in for the PCM5102 of the AB-1.12 prototype.
I doubt the fir/iir setting does anything else in firmware, but I'll have to check to verify.
Børge
=== AB-1.2 and USB-I2S Module === Audio Widget readme ===
Old 6th December 2012, 02:14 PM   #1927
For example sound doesn't improve when I change filter and use AB 1.1 with the ES9022 ( I have also to change usb receiver with later one).
I've asked in the forum to verify if " I'm crazy or not" :-))
I know this setting should do anything to the sound but I can hear clearly an improvement with iir and AK4430 dac.
Can you try with your setup?
Frank
Old 6th December 2012, 02:16 PM   #1928
As regards schematic, I'll post this evening from home.
Frank
Old 6th December 2012, 03:51 PM   #1929
1audio is online now 1audio  United States
Frank
Where is the filter you are talking about? The AK4430 has no filter options.
Demian Martin
Product Design Services
Old 6th December 2012, 05:32 PM   #1930
It's the filter setting in the widget control software.
As I said to Borges, I know that this selection is "only" possible for the PCM5102 dac, ... cause AK4430 datasheet says clearly that only fir filter can be used, ... that I should hear no difference between these two options.
Frank
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2013 diyAudio
