Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd August 2011, 04:33 PM   #181
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
Originally Posted by 2A3SET View Post
I am not sure if we can design a good CCS with low dropout of 1.7V (5v-3.3v) and good PSRR to work with shunt.
Although for best quality I'd definitely use an indipendent power supply with (much) higher voltage, doing that would be great for portable use. Problem is, available voltage is really too small.
Perhaps for portable use you should consider a dedicated DC/DC converter which is completely disabled when providing an external power supply? (I'd say at least 12V!).
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 23rd August 2011, 05:30 PM   #182
UnixMan's Avatar
Default AW USB/I2S with TP "Buffalo" instead of AB?
In the AW thread on our italian forum a friend asked about the possibility to use the AW digital board (USB/I2S module) with the TP "Buffalo" DAC that he already owns. See post #94655, post #p94671, etc.
I'm not sure about all the details, so I ask it here 'cause I bet that there are quite many owners of a Buffalo DAC which may be interested to the answer...
Q: is it possible to use a Buffalo (I, II or III) in place of the AB? how easy/hard would it be to do so?
Q: What modifications needs to be done to the Buffalo and/or to the AW?
Q: What extra circuitry needs to be added?
(perhaps we should start another thread dedicated to this subject?)
Old 23rd August 2011, 06:18 PM   #183
borges is offline borges  Norway
Could you point me to an updated schematic for the Buffalo?
The signals that pass throgh the USB-I2S module are I2S (11.2896 or 12.288MHz bit clock) out and MCLK (same two frequencies) in. The module can be VBUS powered or use an external power supply. The latter case might pose some challenges to bootup and enumeration. But that is only speculation from my side.
Børge
Old 23rd August 2011, 06:41 PM   #184
UnixMan's Avatar
no idea where to find it.
On the TP site there is the page about the new Buffalo III, but I can't find the schematics for it. At the end of the page there are a few links to old Buffalo's (I, II & 32s) documentation, but no schematic whatsoever (except perhaps for the very 1st one).
Old 23rd August 2011, 06:44 PM   #185
2A3SET is offline 2A3SET  Canada
Hopefully this helps, wiring from Musiland to Buffalo II.
Musiland 03 I2S to Buffalo II DAC: Playing 352.8Khz Music H i F i D U I N O
And the Buffalo III manual,
http://www.twistedpearaudio.com/docs...ide_V1.0.1.pdf
Old 23rd August 2011, 06:50 PM   #186
Hi Borge,
The Buffalo III uses the ES9018. Between the users manual and the spec sheets you have you have enough info.
I thought the MCLK from your I2S module ran 22/24 mhz ?
Old 23rd August 2011, 07:28 PM   #187
Hi George,
yes, the MCLK to the DAC is 22/24. But the serial output of the MCU won't run that fast, so there's a /2 JK flip-flop between the XO and the module.
The ES9023 needs to run its sigma-delta modulator at 22/24 in order to have high enough oversampling rates for 176.4/192 input. We could use 44/48MHz MCLKs too. The AB-1.1 board allows for that by coupling two JKs in series to divide by 4. Higher frequencies mean more jitter but also higher oversampling rates. Might be a profitable and audible trade off.
BTW, what is your clock setup like? AB-1.1 MUXes two fixed-frequency XOs from Golledge.
11/12MHz is sufficient for 24 + 24 bits at 176.4 / 192. I use the same rate in my CD player for 24 bits at 352.8 / 384. That leaves 8 dead bits which is practical since running I2S bumper-to-bumper can be a little uncomfortable.
Børge
Originally Posted by GeorgeBoudreau View Post
Hi Borge,
Old 23rd August 2011, 07:32 PM   #188
The manual says:
"The Buffalo III DAC board uses a custom on-board ultra low jitter, low phase noise 100Mhz clock from
Crystek. The clock module lowers jitter significantly when compared to normal clocks. The clock is placed
on the board near the DAC chip to keep phase noise at low levels."
That is not immediately compatible with the USB-I2S module. But I'll have to read a bit more to tell.
Børge
Old 23rd August 2011, 07:38 PM   #189
Hi Børge
I use a Si532 dual output clock into a divider to feed the cpu. Output freq is selected by the cpu depending on the bit rate requested.
Although it makes for a compact board the clock is custom ordered at $20 a pop not including shipping. warning::: do not order small quantities as the courier costs at almost $90 are a killer.
George
Old 23rd August 2011, 09:24 PM   #190
UnixMan's Avatar
as does version two. IIRC Buffalo II by default had a slower clock, either 40 or 80 MHz.
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2013 diyAudio
