Open-source USB interface: Audio Widget - Page 172 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th August 2012, 01:47 AM   #1711
Originally Posted by zumbik View Post
Start from here:
i checked it and the widget shows exactly like above...
whats next..
V
Old 8th August 2012, 02:34 AM   #1712
here is what my screen looks with green and in this nothing works under Foobar and then in red led i cant get anything to play as foobar says there is no ASIO drivers there
Old 8th August 2012, 04:00 AM   #1713
Your ADC type should be set to none.
Your DAC type should be either generic or es9023.
Quirks should be set to quirk_none.
Alex
Old 8th August 2012, 09:06 AM   #1714
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
Originally Posted by borges View Post
If you look at the analog board schematic you'll see that R8 is installed for 2:1 MCLK division. It is possible to remove it and install R11 instead for 4:1 division. That way you can use the 4xMHz frequencies and still provide the 11.2896/12.288MHz required by the MCU.
sounds easy!
What about those Crystek oscillators?
Crystek Corporation CCHD-957 Standard Clock Oscillators | Mouser
http://www.digikey.com/scripts/DkSea...-957%20crystek
are they mechanically and electrically compatible with the ones installed on AB-1.x?
That is, is it enough to simply replace the clocks and R8 with R11 ?
Are there any possible side-effect?
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 8th August 2012, 09:23 AM   #1715
Originally Posted by UnixMan View Post
sounds easy!
Crystals and Oscillators | Oscillators | DigiKey
Was talked about a few days ago:
Originally Posted by hochopeper View Post
I actually tried to work out how to fit a CCHD957 onto the existing AB1.12/13 board layouts a few days ago, just looking by eye at photos of the pcb layouts I think they end up fouling some of the bypass caps and surrounding components potentially? Though I think the pad placement for the golledge parts lines up ok with the CCHD957 pads.
to which 1audio had this suggestion.
Originally Posted by 1audio View Post
Borge would be the best for that. Changing surface mount oscillators looks to be quite difficult in general without some very special tools. You could add some short wires and float the oscillators above the board. Attach a bypass cap beneath them incase the internal bypass is not enough. The isolation from floating them may help since crystals are sensitive to vibration.
In summary I think they should fit though bypass/decoupling caps may be obscured so borges made this suggestion:
That, or you can dead-bug prototype them. Glue or tape them upside-down onto some free boards area and patch the wires onto the SMD pads of the Golledge XOs. Works with both SMD and pinned components. Just check if the case should be GND or float. And remember to put decoupling right onto the dead bug itself. Wires should be insulated and pushed tight to board/XO so that they don't create a loop antenna.
I think that captures most of the relevant discussion on the topic. Outstanding challenges are having the skills + equip to get the existing XO off if fitting to an existing board. I'm not sure if having the xo on an adapter is going to detract from the advantages of having the crystek xo so I'm still weighing up my options, I do think that playing with different XOs is another advantage of having the modular format but obviously making a pcb layout for a few XO types will end up with other compromises.
Old 8th August 2012, 10:07 AM   #1716
borges is offline borges  Norway
The tricky part will be to get the Golledge XOs off, yes. You can do it destructively by drenching the whole XO in solder. The method I use is a tweezer-iron with wide paddles which each cover two pads.
BÝrge
Old 8th August 2012, 05:24 PM   #1717
BÝrge
Borge,
can you help in my problem as i showed earlier the problem is still there...
V
Old 8th August 2012, 06:08 PM   #1718
zumbik is offline zumbik  Europe
Have you changed the settings about which I and alexlee188 wrote before?
On your screenshot I see something completely different ...
(Read post number #1713)
You must choose the same parameters and save them...
Later, you must reset the AB 1.2 (on backpanel)
Your computer supposed to show only this: Click the image to open in full size.
In Foobar2000
/Library/Configure/Output/ASIO "USE 64-bit ASIO drivers" must be OFF
Old 8th August 2012, 10:02 PM   #1719
Originally Posted by thisisvv View Post
Borge,
V
Were you able to change the WidgetConfig view to the one in the attachment?
Remember to press Reset after Save for changes to take effect.
BÝrge
Old 9th August 2012, 02:23 AM   #1720
In Foobar2000
This thing was the problem ...thanks and its working...
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright ©1999-2017 diyAudio
