| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1361 |
is choosing a less facetious title...
yes the divider is awesome i forgot to comment, i was going to be stuck trying to deal with this myself
#1362 | |
A small board with I2S (e.g. IL715) and I2C (e.g. ADUM1250) isolation would be great and all that's needed. Not to mention it'll be usable by all USB-I2S-DAC projects most of which nowadays feature an arduino or something.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones Last edited by TheShaman; 15th March 2012 at 03:50 PM. |
#1363 |
Last edited by RayCtech; 15th March 2012 at 04:18 PM. Reason: I had written a reply and some attached documents that for some reason disappeared.. |
#1364 | |
If you can't trust your ears, then CLICK HERE |
#1365 | ||
Hi Børge,
wow, great news that of the AB112+1.13 "Easter Egg"! ![]() Quote:
IMHO, on the AB board(s) there should be only the DAC, the clocks and whatever else is strictly required to be on "the clean side" and/or may be required to control DAC (or digital output) operation such as I2C, etc. Anything else should be moved to the USB board.
#1366 | ||
"Synchronous MCLKing scheme for ES9018", from thread "ESS Sabre Reference DAC (8-channel)", post #1883.
#1367 |
Finding quality audio crystal oscillators is not easy. Most are custom (or surplus from someone's custom run). The Golledge oscillators Borge has seem pretty good. On my AB1.1 the 48K has less jitter and is pretty free of deterministic sidebands. The 44.1 chain is not as pretty. It may be the oscillator.
Crystek has very good oscillators that are now available from Digikey and Mouser in 22,24,44,48 MHz for audio. At $30 they are not cheap but very high performance. The next step in performance is much more and much longer lead times. Phase noise gets worse as the frequency goes up. 100 MHz is near the highest for oscillators. Above that you use multipliers etc. The performance degradation come from the Q being less on higher frequency crystals. They get really thin at those higher frequencies. The lowest phase noise is 4-5 MHz. The NDK oscillators look interesting but not available here easily. Tent Labs has an assortment but is missing the higher frequency oscillators. I could make a simple doubler circuit to get 2X 44&48 with low phase noise. It will be analog/rf stuff plus digital stuff. It may be the best option, although multiplying the 22/24 up may be even better.
Demian Martin Product Design Services |
#1368 |
any thoughts on doing something like from AN67 for a XO? that is if its useful at correct speeds
#1369 |
Please provide more details, AN67?
#1370 |
ahh sorry i figured you would know it, probably you have seen it. it will require very high quality layout and its not cheap, but would be tweakable for frequency output, in fact multiple frequency output should not be too difficult provided it can be gotten up to useful speed and you will know that better than I
Linear Tech Application Note 67. from Dale Eagar a composite opamp Wein Bridge type oscillator. i have all the opamps it needs funnily enough |
| Async 192Khz USB - the SDR-Widget collaborative project | SunRa | PC Based | 5 | 26th April 2011 06:38 PM |
| usb audio interface | david12 | Equipment & Tools | 14 | 10th October 2010 02:58 AM |
| Cheap Audio Interface (USB?) to PC | agm2003 | Instruments and Amps | 11 | 16th September 2007 07:48 AM |
| Open call for suggestions on Open Source DIY Audio Design | gfergy | Everything Else | 1 | 15th April 2007 07:33 AM |
| USB Interface Perfect?- Computer Audio | fmak | Digital Source | 3 | 4th December 2004 10:24 PM |
