Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
I-V circuit question
Old 11th January 2002, 05:58 PM   #1
tiroth is offline tiroth  United States
Default I-V circuit question
I have a question that I hope someone has time to answer. In the output stage of the AD1853 demo board there is what is almost a standard opamp I-V converter combined with some filtering. However, the noninverting input is connected to VREF through a 402R resistor rather than to ground.
For some more background on this DAC, the output current is 3mA p-p with 1mA into the DAC's IREF. 1mA is achieved by applying 2.7V (VREF) to FILTR on the DAC and connecting IREF to ground by 2k7 resistor.
Is this arrangement intended to account for variations in VREF?
I would guess that the differential outputs of this circuit are 6.18V p-p. Is this correct?
[To avoid confusion, note that I have specified 'I' in before the current-source inputs and the Vout designators are mine. Is the polarity correct?]
Thanks very much,
Tyler
Old 11th January 2002, 07:01 PM   #2
paulb is offline paulb  Canada
I don't have a lot of background in I-V converters, but it seems to me that even though they are current outputs they still have a limit on their voltage swing, and my guess is that the DAC has a single +5V supply, so the output is centred around 2.7V for Vref. The op-amps run from a higher-voltage, bipolar supply so that they won't be handling voltages anywhere near their supply rails, but their reference has to be the same as the DAC.
Does that make sense?
Old 11th January 2002, 07:10 PM   #3
Ah, I see. That makes a lot of sense. I think I am too used to thinking of signals referenced to ground. ;)
Thank you.
Old 18th February 2002, 01:10 PM   #4
capslock is offline capslock  Europe
Default resistor
Paul is completely right. The caps provide AC ground, but the reference output must have a DC bias because the DAC is single supply.
I am a little puzzled about the 400 Ohm resistor. It could be meant to provide the same impedance as on the other op - amp input. This will lower offset voltage in high input current amps such as the AD797 but it does not really make sense for the OP275 (which is junk, but the way).
The other idea would be to decouple left an right channels. Then the resistors would be perfectly suited. However, then a another capacitor to ground at each op-amp non-inverting input would make even more sense...
Old 18th February 2002, 01:40 PM   #5
HarryHaller is offline HarryHaller  United States
Banned
Default I/V input resistor
My guess is it is there to protect the input stage of the op amps when the power supplies are coming up at turn on. Op amps don't like large differential voltages on the input pins. During normal operation this voltage is very small. The resistor will limit the current into the input stage during fault or power up conditions.
H.H.
I-V circuit questionHide this!Advertise here!
Headphone amp circuit question. Artie Headphone Systems 5 15th April 2009 07:32 PM
Aikido circuit question jayme Tubes / Valves 3 14th September 2007 09:31 PM
circuit board question mike49504 Car Audio 0 5th August 2007 07:48 PM
Quick circuit question Thunau Parts 0 20th September 2003 08:09 PM
Aleph P1.7 circuit question Peter Daniel Pass Labs 6 22nd May 2002 03:43 AM
Copyright ©1999-2017 diyAudio
