Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st March 2011, 04:35 AM   #1
Default Need help with Marantz 6000 output terminals
Hi there
Fred from Adelaide, South Australia. This is my first post, and sorry it's already one that's asking for help rather than offering any.
I have a CD 6000 OSE LE which has been ailing for a while - the right channel of the player's analogue output terminal (where you connect it to the amp via interconnects) has gone bad, probably through too much plugging and unplugging of the interconnects. There's no sound/signal unless pressure is put on it from a certain direction.
I reckon the output unit needs to be changed. It this something that could be easily diy-ed at home? Would really appreciate if anyone could point me in the right direction of getting the correct part and replacing the defective one. I've thought of getting it fixed in a service centre but unfortunately Adelaide doesn't have one.
Would be most appreciative of any feedback.
TQ.
Old 21st March 2011, 05:58 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Hi, Sounds like the RCA connector has broken off from the pad of the pcb.
Just resolder it and you are back in business. singa
Old 21st March 2011, 06:46 AM   #3
Hi Singa (lion? panthera leo?)
Thanks so much for the reply. Not sure if it has completely broken off. It only affects the right channel though. And when some pressure is applied, say, with a rubber-band) the sound comes back. Thanks, matey.
Fred
Old 21st March 2011, 07:24 AM   #4
Mooly's Avatar
I agree... most likely the soldering has cracked. Only one way to find out
Also just make sure the lead/plug itself is OK.
A simulation free zone. Design it, build it, test it.
Old 21st March 2011, 10:01 AM   #5
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Just my 2c worth ...
The connectors on most Marantz cd players are rubbish !!
The "gold plating" is only on the outside of the ground so is almost worthless.
If you are "going in" , it might be an idea to completely remove the rubbishy Marantz connector and replace them with individual sockets. It's a simple job and the results will be worthwhile for the sake of an hours time, a yard of wire and a couple of sockets.
Andy
PS:- Possibly Singa as in Singapore, the Lion city.
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 5th August 2011, 11:15 AM   #6
Having just joined the forum and posted a thread describing almost exactly this same problem, I'm very interested in this thread.
How easy is it to do this solder repair? (baring in mind I'm a bit ham fisted when it comes to soldering...lol)
Old 5th August 2011, 06:24 PM   #7
Mooly's Avatar
Replied on your other thread...
Marantz CD-6000 Manual poynton Digital Source 2 10th November 2007 04:21 PM
Marantz 6000 Problem Sabas Digital Source 0 20th June 2006 11:19 AM
Marantz 6000 ose error davidsrsb Digital Source 18 30th December 2005 11:26 AM
Marantz 6000 OSE Tweaks deepug Digital Source 0 3rd March 2005 06:39 AM
Page generated in 0.08923 seconds (76.54% PHP - 23.46% MySQL) with 10 queries
