Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st March 2011, 04:31 AM   #1
Default Any Shengya cd-s10 owners?....I need your help
If anyone still has this cd player I desperately need your help. An amplifier of mine failed and sent a large amount of DC back into my shengya cd-s10 and fried a single resistor labeled R156, located between the output tube and the RCA outputs. The color bands of the blown resistor are completely unreadable.
I was wondering if anyone still owns this player (it hasn't been made in quite some time) if they could pop it open and let me know the value of R156. I did find a few pics that had been previously posted of the internals but they were far to pixelated to read the color bands with any confidence. Any help would be appreciated.
Thanks,
Chris
Old 22nd March 2011, 08:32 AM   #2
Mooly's Avatar
If it's just to the RCA sockets then it sounds like either a series feed, in which case there would be a similar resistor for left and right. Valve output... so it's got to be AC coupled anyway... so probably not a series feed!
Or... it could be a ground lift resistor from audio/chassis ground to the RCA ground which is normally low in value, usually around 1 to 10 ohms and not critical.
Knowing the voltage that was applied would be a clue as for example 20 or 30 volts won't burn anything over say 1 to 2 k depending on wattage.
Edit... post some close up pics of the top of PCB and the print side too.
A simulation free zone. Design it, build it, test it.
ShengYa cd-16 CD player lependule Digital Source 1 10th November 2010 01:21 AM
Shanling CD-S100se Owners - Help! Mayank Digital Source 0 17th November 2009 01:26 AM
Tannoy S10 noyan Multi-Way 1 10th January 2008 04:04 PM
Shengya CD-20 or CD3 CD Player WALTER BURKHARD Digital Source 0 2nd May 2007 07:30 PM
Sheng Ya S10 CD player Modz AnthonyAsh Digital Source 4 28th October 2006 02:14 AM
Page generated in 0.05783 seconds (78.59% PHP - 21.41% MySQL) with 10 queries
