| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a severall peaces of Vishay low ESR caps, I would like to try how they sound. What would be the best place for add those caps in a CD player?
1.Like decoupling caps on analog output stage (in this moment im using Muse) 2.Filtering the PS of analog output (in this moment im using Muse) 3. Filtering the PS of DAC (1541) (now im using SMD electrolytics-i dont know the producer) 4. Filtering the transport (in this moment cheap Nichicon) |
#2 | |
Looking at your board I wonder if you replace yet the OpAmps after the DAC or they are still the originals... That would make a bigger difference.
As for low ESR I will put this quote that I agree with: Quote:
High End Audio - Electrolytic capacitors |
#3 | |
#4 |
Low ESR caps can sometimes create problems when used to decouple supplies for digital chips, as a higher ESR helps damp resonances with smaller parallel decouplers.
#5 |
#6 |
If the PCB was designed for ultra-low ESR is not a problem. Like in a PC power supply. But if your board was designed for regular litycs plus ceramic bypass caps, is better not to use low ESR lytics because the risk of unwanted osscilations with the power bus inductance.
I did replace the 833 with some sockets for testing and I did try some other opamps. LM4562 was my final choise. |
#7 | |
About sockets its a good idea i was thinking about also. In this moment i have only NE5532 is it wort to put them instead of LM833? My final idea is to build a one stage tube preamp connected directly to the output of TDA1541. |
#8 |
Your board was not designed with low ESR in mind. The best you can do is 0.1uF decopling caps between each power pin and ground (not between the power rails).
NE5532 are not better than LM833... Use LM4562NA/NOPB (8DIP version) or other SMD (like AD8599) with adaptors. I did try also NJM2068 and OPA2209 (in 8DIP capsule) but the best sounded 4562. Last edited by SoNic_real_one; 11th March 2011 at 09:01 PM. |
#9 | |
Best regards |
#10 |
Let us know what is your oppininon about them after swapping.
| low esr caps....... | wendell | Parts | 12 | 29th April 2008 02:07 PM |
| Low ESR caps in SMPS | Stuey | Power Supplies | 2 | 19th May 2007 06:35 PM |
| Low ESR Caps | audioPT | Parts | 5 | 1st August 2004 11:39 PM |
| Low ESR caps? | DanK | Solid State | 1 | 7th September 2001 01:52 AM |
