| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I don't know too much about the theory of dither, but I think it is correct to state that it improves low level linearity. Then I know that either the CD record may contain added dither, or the digital filter may add dither during playback.
If the above is correct (please confirm) then would it be possible to generate dither in hardware and add it to the bit samples? I mean building a random signal generator (PRBS) and some logic circuitry into the CD player could do it. |
#2 |
Banned
Dither is added to randomize patterns that arise in quantization. Production CDs normally have dither added at the mastering stage e.g when the sample rate is reduced from 24 to 16 bits. The rounding-up and -down which takes place is randomised so that an overflow of 0.1 will be rounded up once for every 9 times it is rounded down, the pattern of 1-to-9 roundings being varied randomly.
I don't think it's practical to add dither at playback, it requires knowledge of the signal being processed (downsampled or filtered), and I can't see a good reason for doing it. w Last edited by wakibaki; 8th March 2011 at 01:30 PM. |
#3 | ||||
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#4 | |
Custom Title
Of course, you'd want this switchable.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#6 |
Like it was said before addind dither reduces the available bitdepth. That's why it can be done to the original 20-24 bit signal when is converted to 16 bit.
Addig dither to an existing 16 bit signal is possible only if you can live with resulting 14-15 bit of data (or less). And it won't "improve" the quality of the original signal, it will just make those "lesser" bitdepth samples to sound better that the same bitdepth samples obtained without having the dither applied at the conversion/truncation. Last edited by SoNic_real_one; 8th March 2011 at 04:51 PM. |
#7 |
Use a PMD100 (or 200 if you can ever find one). It can add dither (several levels of dither) towards the dac. Seems to have a positive effect specially for (old) multibit dacs (pcm63 etc). Have a look at the datasheet.
I've done some testing with one and a spectrum analyser and could clearly see a drop in the noisefloor in the audioband when dither was added. Together with a rise in the noisefloor outside the audio band (no such thing as a free lunch).
GuidoB |
#8 |
in theory the HDCD case is another example of adding dither to a higher resolution digital stream - HDCD uses compression/expansion in coding the CD so they claim up ~20 bits of dynamic range
the dither is being added to the expanded/decoded HDCD "higher resolution" bit stream to still drive 16 bit DAC |
#9 |
That is only the case of PCM100. Latter implementations (via DSP) drive directly 20 or 24 bit DAC's.
#10 | |
GuidoB |
| Adding a Supertweeter.... | raypalmer | Multi-Way | 17 | 4th September 2011 08:07 AM |
| Adding a Potentiometer | marian99 | Chip Amps | 29 | 22nd March 2009 10:33 PM |
| Adding capacitor | built | Car Audio | 8 | 17th October 2007 02:27 PM |
| How to Control Dither on PMD100 Chip? | fastcat95 | Digital Source | 1 | 1st September 2007 11:36 PM |
| adding capacitor | DREW028 | Solid State | 21 | 19th July 2004 08:35 AM |
| Page generated in 0.11534 seconds (81.44% PHP - 18.56% MySQL) with 10 queries |
