Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st July 2003, 10:22 PM   #1
Lichoo is offline Lichoo  Poland
Default Power supply
Hello,
I'm going to tweak the power supply in my CD6000 and put another 10VA +/-12V trasformer for the analog section. I'd like to improve also filtering in the supply so I'm going to put larger capacitors. What is the best way to do it:
1) put 4700uF before stabilizer and leave 470uF after stabilizer
2) leave 470uF before stabilizer and put 4700uF after stabilizer
3) put 4700uF before and 4700uF after stabilizer
4) any other combination?
Piotrek
Old 1st August 2003, 12:25 AM   #2
djmiddelkoop's Avatar
What kind of regulator ?
A LM317 outperforms a 78XX easy.
For the electrolytics, quality is more important than value.
Dick.
Music is the best F.Z.
Old 1st August 2003, 12:34 AM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You might try to read those threads:
http://www.diyvideo.com/forums/showt...5&pagenumber=1
http://www.audioasylum.com/audio/twe...ges/36827.html
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st August 2003, 06:46 AM   #4
According to the scheme, L7812/L7912.
There will be Panasonic FC caps.
Piotrek
Old 2nd August 2003, 10:09 AM   #5
Dick.
Hi
An LM317T is quite noisy, it depends on the application if it is OK
Measurements show output current noise in a band of 20 kHz = 0,7mA. This is never published in the datasheet........
best regards
Guido
Guido Tent
www.Tentlabs.com
Old 2nd August 2003, 10:41 AM   #6
Terry Demol's Avatar
Originally posted by Guido Tent
Hi
best regards
Guido
Hi Guido,
Can you elaborate on this. Normally current noise is at IP
of a device and reacts with driving impedance to develop
a noise voltage. How does OP current noise work, with an
OP Z that is very low I don't see how it can develop any voltage?
Or are you referring to current at ref point (to gnd).
Terry
Old 2nd August 2003, 11:35 AM   #7
[QUOTE]Originally posted by djmiddelkoop
[B]What kind of regulator ?
No longer true. LM317 is very noisy compared to new generation 78xx such as NJM. The 5V one is 40 uV wideband. Also new generation doesn't mind large lytics and likes low impedance output caps.
Old 2nd August 2003, 03:27 PM   #8
Originally posted by Terry Demol
Hi Guido,
Terry
Hi Terry
The noise source behaves as a current source generating output noise current on top of the DC voltage.
Shorting it (with a cap) will reduce the output voltage noise, but will still force noise current to the point of decoupling (often ground)
A series resistor of 10 ohm helps, but still isn't working out like I would like to see it
Guido Tent
www.Tentlabs.com
Old 2nd August 2003, 03:34 PM   #9
Bricolo is offline Bricolo  France
Bricolo's Avatar
[QUOTE]Originally posted by fmak
[B]
how can you see if a 78** is from the old or the new generation?
Old 2nd August 2003, 03:36 PM   #10
Hi Fred
What bandwidth is used when specifying 40uV?
Guido
Guido Tent
www.Tentlabs.com
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.11000 seconds (79.30% PHP - 20.70% MySQL) with 10 queries
