Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd March 2011, 03:19 PM   #1
Default Theta Data Mods?
I found this when I searched, so I guess it's a dead issue...
Recommended mods to a Theta Data Basic II transport
However, I found some photos of a rather extensively modded Data Basic II on line, and was wondering if the experts here could comment on what was done and why. The site is all in Japanese, so I couldn't read any of it.
It looks straight-forward; however when I try to search the maker of the clock, I get a japanese site. I assume there are englisg speaking sellers with similar (or better?) outboard clocks.
Also, the hook-up is confusing to me. A GND and two CLK connections are shown. Is this correct? Is there a polarity or something that has to be adhered to?
Anyway, here's some pics (outboard clock mod):
"When the world is running down,
you make the best of what's still around."
Old 3rd March 2011, 03:20 PM   #2
And here are the other mod photos I found:
It looks like the power switch is hooked directly to the fuse and input connection to bypass board traces I assume. That much I can figure out. The big yellow things: Filter caps maybe? Something else?
Old 3rd March 2011, 03:21 PM   #3
More photos:
Old 3rd March 2011, 03:24 PM   #4
More photos of the mods:
I'm guessing the caps on the transport board wre up-graded; similar with the main board?
Old 3rd March 2011, 03:25 PM   #5
And still more!
Power supply caps probably changed, and a transformer was replaced with an R-core one, mounted forward of the original power board...
Also, the SPDIF cablewas replaced here with a shielded one. I don't know the value of that mod inside a metal box, but... Some other caps have been changed as well.
Old 3rd March 2011, 03:26 PM   #6
Last three photos:
Close up of the output cable ans overview shots of the complete job.
Old 3rd March 2011, 04:29 PM   #7
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
The aftermarket clock is similar to many available on Ebay.
http://cgi.ebay.co.uk/Low-Jitter-clo...item33556beada
The clock module is available on its own.
Valab 1PPM 11.2896 MHz Low Jitter TCXO on eBay (end time 09-Mar-11 17:05:57 GMT)
Although other better clocks are available..
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 3rd March 2011, 04:33 PM   #8
That appears to be the chip in the clock in my first post.
I assume I would need the rest of the board too... Maybe VALab sells the complete board?
Old 3rd March 2011, 04:54 PM   #9
I must have replied before you finished typing...
Anyway I am now watching those two items. It appears that board is different from the one in my first post, but should be workable.
You mention 'better' clocks. Could you enlighten me further?
Old 3rd March 2011, 07:15 PM   #10
poynton's Avatar
The board is different but almost the same if you look closely.
It's really the "chip" which makes the difference in this type of clock.
Similar "chips" are available from Tent Labs.
An example of a better clock is :-
Premium low jitter clock cd player dac - Fidelity Audio on eBay (end time 19-Mar-11 19:45:50 GMT)
andy
Theta Data II tranport screen blinking - help! centaurus3200 Digital Source 0 17th February 2010 03:23 AM
Theta Data II cutting out centaurus3200 Digital Source 9 12th February 2010 08:34 PM
Looking for a mechanical part for Theta Data Basic Jim Leach Parts 8 11th February 2010 07:02 PM
Recommended mods to a Theta Data Basic II transport tankertop Digital Source 0 5th August 2008 08:30 PM
Theta Data Basic II - I2S? Roscoe Primrose Digital Source 4 22nd June 2006 09:59 PM
Page generated in 0.10361 seconds (79.06% PHP - 20.94% MySQL) with 11 queries
