Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th February 2011, 04:06 PM   #1
redbob is offline redbob  Canada
Smile cd player as dac
Need help to find digital input in Hafler Iris cd player.This is classical philips machine.Saa7210p,Saa7220p/b and Tda1541a, with digital output.After it stop spinning I thought it can be good dac.I will use Sony playstationI as transport,any input will be very helpful
Old 25th February 2011, 08:15 PM   #2
tiefbassuebertr's Avatar
you need a conversion from Sony/burr-Brown format to a I2S format from Philips. This is exact the reverse function from follow project:
http://www.analog.com/static/importe...60163AN207.pdf
More complicated it will be, if you go the detour via the SPDIF (S/P-DIF, DOBM) format.
For the conversion from I2S to SPDIF there is the PCF2705 go to
Pcf 2705
Basiclly the same IC (but for conversion from Sony/burr-Brown to SP-DIF) you will need in your application - perhaps one of the members know the appropriate type.
Additional you will need a PCF2705, but with the reverse function (conversion SPDIF-I2S). The Cambridge Audio DAC "DACMAGIC" uses such a device in it's input aera.
Certainly PCM decoders from SONY are configurable to various output formats - sometimes even I2S. If this so, then you can go the easist way. Which PCM decoder (CXD1165-CXD1167-CXD2500Q/AQ/BQ) is in use by your playstation I ??
Old 25th February 2011, 09:01 PM   #3
Thanks Tiefbassuebertr,,looks like little harder than I thought.I will check playstation chip.I am trying to upload pictures of cd board
Old 25th February 2011, 09:20 PM   #4
Maybe,better way is deicated transport with I2S, can you help me find where is digital input,...where to look?
Old 26th February 2011, 03:25 AM   #5
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Why not repair the original machine?
Its a basic Philips model with a single crown TDA1541A
CDM4 drives are readily available although it is more likely to be the 47uF cap giving trouble - VERY common
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 27th February 2011, 07:06 PM   #6
barry.childs's Avatar
Andy's right. A simple repair on a fairly good machine versus a very complicated upgrade to use with a playstation
Old 28th February 2011, 05:27 PM   #7
Hi guys, thank you for input.I will try to check transport again.I am still wondering where is digital input..Saa7210 or Saa7220
Old 28th February 2011, 07:14 PM   #8
poynton's Avatar
There is no digital input as such.
Andy
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
CD player DAC paintrodsey Car Audio 0 13th September 2006 05:32 PM
Use a DAC of a CD-player ? arold19 Digital Source 31 3rd November 2004 02:38 AM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
DAC Upgrade for older Carver CD Player: LC7881-C DAC M_Anker Digital Source 3 11th December 2001 11:45 PM
Page generated in 0.09729 seconds (79.86% PHP - 20.14% MySQL) with 11 queries
