Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th February 2011, 08:18 AM   #1
Default Rcd 965 le problem
Hai, I need some help eith my rotel 965 bx le
I have not used the player for more 1 year, now it takes long time to recognise cd and start skipping from track 1
I try to clean the lens, but the problem still the same !, please give me some sugestion to solve this problem.
many thanks
Old 24th February 2011, 10:06 AM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Selamat datang di forum
What did you clean the lens with ?
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 24th February 2011, 11:25 AM   #3
I use clean cutton and wipe the lens
Old 24th February 2011, 01:03 PM   #4
poynton's Avatar
Did you use any liquid ? Alcohol etc.?
Only proper lens cleaner should be used with clean cotton buds.
Does the swing arm mechanism move freely from stop to stop ?
Do you have a manual ?
have you tried setting the player into diagnostic mode ?
Andy
Old 25th February 2011, 12:08 AM   #5
No, I didn,t use any liduid, the lens looks clean!, the swing arm is ok, I just down load the service manual, no I havenot setting the player into diagnostic mode!, how to do it?
Once I repaired my old pioneer cd changer, after I change some of tha capasitor the unit work well!, is this also the problem with RCD965!?
thanks
Old 25th February 2011, 03:33 AM   #6
poynton's Avatar
To be honest, it is a long time since I looked at an old Rotel.
If I remember correctly, it has the cdm4 and is based on a Philips player.
Search the forum for CDM 2 and cdm4 problems. There are capacitors used which are famous for going "off". ( 47uF )
If you do change them, DO NOT increase the value or use Oscons. Use like for like.
Also read this thread ....CDM4/19 skips
Andy
Old 25th February 2011, 06:22 AM   #7
I,ll try to change the cap and let you know the result later, thanks Andy for your sugestion.
Old 4th March 2011, 08:05 AM   #8
Hai Andy, I have changed the capasitor but, the problem remain. do you have any sugestion! thanks
Old 5th March 2011, 07:42 AM   #9
Mooly's Avatar
First check has to be the RF signal (eye pattern) as viewed on an oscilloscope to confirm amplitude etc is good.
As Andy says, failing caps are a real problem with the old Philips units...
Isn't there a 33uf cap that always gets mentioned, is that on this unit ?
A simulation free zone. Design it, build it, test it.
Old 5th March 2011, 10:12 AM   #10
poynton's Avatar
Did I say 47uF ?
rotel RCD 965 BX paul_peraic Digital Source 22 24th October 2010 05:58 AM
Rotel RCD-965 BX problem antony28 Digital Source 8 11th October 2010 07:33 AM
Rotel 965 LE CD Player Belt Measurements audio44 Digital Source 1 31st August 2010 03:44 PM
RCD 965 Muting Transistors to a Relay. How? (components or something I buy/install) KP11520 Digital Source 16 11th July 2007 04:17 PM
Page generated in 0.11002 seconds (83.00% PHP - 17.00% MySQL) with 11 queries
