| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
![]() ![]() this is the circult of korg mr-1 the opamp RC4580 is really bad n I found that the lineout and phone out seems have to pass through this opamp however there is limited choice for opamp..as mr1 just provide 5v power supply and no space can any one suggest any method to improve the sq? i don mind if i have to change the opamp or bypass i just need the line out and recording function |
#2 |
the opamp is on the top left corner of the left picture..right above the phone out
#3 |
go and read the threads on experiences with SMD assembly and SMD component swapping.
If after that you are confident you have the tools and skills to carry out the modifications come back and ask again.
regards Andrew T. |
#4 |
How to work on SMD,
Working with SMD. How to do it without specialised tools.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#5 |
Also check to see if any of the resistors around it are fried. If they are, the value may be unreadable. Then you need a schematic.
#6 |
yeah i don believe in my skill as well...so i just ask my fd to do it
this player is really strange...i can adjust the line out volume |
| CD player opamp upgrade -advice needed | stevew7280 | Digital Source | 9 | 8th October 2010 06:02 PM |
| Opamp I/v For Ad1865 Need Advice | rubydac | Digital Source | 0 | 21st February 2008 06:24 PM |
| CA 640P opamp advice please | ben556473 | Chip Amps | 5 | 17th November 2007 03:10 PM |
| RIAA opamp phono stage advice | mp741 | Analogue Source | 19 | 7th February 2006 08:49 PM |
| Page generated in 0.08646 seconds (75.38% PHP - 24.62% MySQL) with 10 queries |
