| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
My Wadia 6 (Drive: VRDS CMK-4 Laserunit: KSS-151A) suddenly starts t develop problems like: - skip parts of tracks; - can't find a track - hangs. It reads the TOC, and sometimes it plays a CD without any hickup the same that gave all the trackingerrors. Player does generate a mechanical tick that slows down when of course it is working towards the outer tracks where it spins at lower RPM. I know that there is some discussion that just swapping the Laserunit is not the right way to attack these problems because it has to do with the electrical circuit that moves the lens up and down or (focussing) or the trackingcircuit that moves the complete laserunit along the glidingrod. Read this very informative piece from Lukasz Fikus the 'Lampizator': Laserology Did of course open up the Wadia and performed all the steps and 'deepcleaned' the lens. Any suggestions how to proceed? |
#2 |
It's no good guessing... the first step has to be a detailed look on a scope at the quality and amplitude of the RF signal. If the quality is poor/low amplitude and the unit is adjusted correctly then the pickup is definitely suspect.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Fortunately sounds exactly like a lubrication issue. Being linear motor, the tracking is very sensitive to proper lubrication of the sled guide rail. Clean the rail thoroughly, then relubricate with something between a grease & an oil. I use Nye Lubricants 'Rheolub', which is made to lub high end mixer slide pot guide rails, and it works beautifully. A fairly thick oil would work temporarily, for diagnostic & 'until you find the grease' purposes.
| Wadia 6 | nelsondog | Swap Meet | 0 | 15th February 2010 05:32 AM |
| Sony CDP-X222ES tracking problems | gorfeas | Digital Source | 7 | 26th April 2007 01:10 PM |
| tracking regulator to solve everyone's problems? | mazurek | Solid State | 0 | 5th June 2006 01:36 AM |
| Tracking / Alignment problems with (old) TEAC MV-306 VCR | AudioFreak | Everything Else | 8 | 11th July 2003 03:43 AM |
| Page generated in 0.07118 seconds (75.56% PHP - 24.44% MySQL) with 10 queries |
