Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
EZDAC two-box DAC built, finally!
Old 22nd January 2011, 02:20 PM   #1
baldrick is offline baldrick  Canada
Default EZDAC two-box DAC built, finally!
After a false attempt at building ezkcdude's EZDAC I have finally completed a working version.
I wanted to do a two box DAC with the power supply and the DAC in separate boxes.
The complete DAC uses a 12VAC wall wart supply, with the power supply box doing rectification and regulation to +/- 15VDC using ezkcdude's EZDUAL power supply project.
Two box completed DAC:
The lower box is the power supply with the black power switch. The upper box is the DAC with a front panel selector switch for selecting coaxial or Toslink input.
This is a shot of the inside of the DAC box. Notice the perf board "daughtercard" which converts Toslink's TTL signal to spdif standard.
Here's a closeup of the inner side of the rear panel:
Those of you with a keen eye will recognize this as version 1.0 of ezkcdude's EZDAC board. The latest v1.5 version of the board now comes with a soldermask. It should make soldering far easier. I've bought one of these v1.5 boards for a later souped up EZDAC project.
Here is a closeup of the daughtercard that converts Toslink TTL signal to spdif:
I decided to do a "standard" build of this project. So I pilfered ezkcdude's EZDUAL power supply project for the power supply. I am using a 12VAC wall wart to power the supply. This kept everything simple and safe:
In a fit of blind ambition I even created a "silkscreen" for the pc board using the laser toner transfer method:
Finally here's a shot of the inner side of the rear panel:
So the thing actually works and works very well. I'll post listening notes a bit later.
Cheers
Baldrick
EZDAC two-box DAC built, finally!Hide this!Advertise here!
So, I finally built a 3 channel cmoy TheSeekerr Chip Amps 11 23rd October 2008 10:15 PM
Finally built a subminiature guitar amp... now I need help! Hendrixon Instruments and Amps 8 20th March 2007 01:16 AM
I finally designed and built my first crossover! Jim85IROC Multi-Way 17 26th May 2004 08:27 PM
Finally built something :) wintermute Multi-Way 9 14th February 2004 01:25 PM
finally built a gainclone nobody special Chip Amps 5 27th January 2004 09:32 AM
Copyright ©1999-2017 diyAudio
