Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips cd-471 mods
Philips cd-471 mods
Old 26th January 2011, 07:55 PM   #11
Magura456 is offline Magura456  Netherlands
Today i spent a little time at my cd-471..
I put copperfoil on the 3 biggest chips and couple it to ground with ceramics caps.
I tought it was voodoo to put some coppershield on the chips... but i must admit, that it works very well!
The dynamics seems to be improved. I'm happy with it!
Old 26th January 2011, 08:58 PM   #12
amc184 is offline amc184  New Zealand
amc184's Avatar
Philips cd-471 mods
I drew up a diagram on how to connect an external power supply to the SAA7220, it's a pretty easy job. A couple of caveats though:
- Make sure your supply is actually putting out +5VDC, or at least very close to that.
- The SAA7220 is going to burn through 180mA while operating, make sure your supply can actually handle that.
Old 26th January 2011, 09:02 PM   #13
amc184's Avatar
Philips cd-471 mods
Oh, and I almost forgot, you'll have to ground the supply as well of course! Use that grounded link labeled 116 on the diagram.
Old 27th January 2011, 03:54 PM   #14
This is great! Thanx.
I'm gonna start with a standard lm7805. after that i have some burson audio super reg for further improvement. Maybe i put a alwsr super reg on this chip.
I want to put seperate toroids for the chips like saa7220p/b, saa7210, tda1541A. I'm searching for 30 or 50 va toroids because this fit into the case.
Probably is 2 toroids the max for this player, but i have to measure that.
Capacitor 2605 is already changed for a sanyo oscon 47uf/16v.
Is this good enough? I have some panasonic fc/fm lying around.
pics later...
Old 27th January 2011, 07:17 PM   #15
amc184's Avatar
Philips cd-471 mods
The Sanyo OSCON should be fine.
Old 10th March 2011, 08:51 PM   #16
This week i build a psu with a low noise regulator from Burson for the saa7220p/b. Improvement all the way
The transformer is 2x15v 30va, schottky diodes, lm7812,rubycon zlh+zl 1000uf caps with burson super reg.
Thanx amc184
Old 19th March 2011, 04:27 PM   #17
This is only test setup. I need to rebuild the circuit a lot smaller.
Next step is a second psu for the saa7210 or tda1541A.
It plays already very nice.
Old 19th March 2011, 11:30 PM   #18
SoNic_real_one is offline SoNic_real_one  United States
You are sure that you did hear improvements or it is just a wishfull autosugestion?
SAA7220 is a crappy/jittery OS/filter cip by today standards, I cannot see how you can improve it with just a power supply.
I can admit something like that for the TDA1541... but even there I would be doubtfull.
Old 20th March 2011, 03:51 AM   #19
amc184's Avatar
Philips cd-471 mods
It's just as much about improving the supply to the rest of the player. The SAA7220 is a power hungry IC and very noisy, and tends to contaminate the power supply to the rest of the player. Did you actually do much of a comparison Magura?
By the way SoNic_real_one, you have a lot of harsh words about the SAA7220, especially its jitter performance. What measurements are you basing your criticism on?
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 20th March 2011, 09:34 PM   #20
Yes, itīs not a totally different sound but more subtle improvement.
With the shiga clone psuīs i noted differences like more "relaxed" sound.
So i build a psu with a low noise super reg to test it with this player.
Philips cd-471 modsHide this!Advertise here!
Philips CD 721 or Philips CD 710 info5 Digital Source 3 19th July 2012 09:15 AM
Philips cd 471 diymax62 Digital Source 13 20th May 2012 04:10 PM
Philips CD-471 DrJayDee Digital Source 3 27th May 2008 12:03 PM
Philips CD 160 mods? spiderze Digital Source 6 19th January 2008 09:56 AM
Philips CD 471 schematic padamiecki Digital Source 0 8th December 2004 06:56 AM
Copyright ©1999-2017 diyAudio
