Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Problem with connecting PCM2707 to USb
Old 12th January 2011, 08:30 AM   #1
kiranp is offline kiranp  India
Default Problem with connecting PCM2707 to USb
I have rigged up a circuit which is used for USB to I2s conversion..
I am using PCM2707 IC from Texas instruments...
And i have attached the schematic of my board also.. I am facing problems in making it recognized , meant to say that when i connect the PCB onto USB port.. A message pops up on windows saying USB not recognized...
I dont know what fault is in my Schematic.. I cross checked the wiring , the components many times .. but didn't find any mistakes..
Can anyone please guide me in getting the work done...
Thank you,
Kitty
Old 13th January 2011, 05:33 AM   #2
lakeside is offline lakeside  United States
lakeside's Avatar
I believe pin 3 (HOST) should have a connection to Vcc.
~Mike
Old 13th January 2011, 08:11 AM   #3
Some designs have it connected to VCC and some to ground.. I tried both combinations but didnt work
Old 13th January 2011, 08:59 AM   #4
rrrremus is offline rrrremus  Germany
Take a look on the configuration i use for PCM2706.
Uploaded with ImageShack.us
Old 14th January 2011, 04:07 AM   #5
Thanks for the circuit... But i don find much changes in yours and mine.. Mine is Bus powered and yours is Self powered.
Then you have connected all the Analog Vcc's to 3.3V and i have connected to ground.. I think , this will not be of much concern..
But whats that AND gate doing with that HOST pin???
Old 14th January 2011, 04:55 AM   #6
The gate is there to prevent HOST detection while the DAC is powered off; the chip can be configured to run bus-powered.
Does your PCM2707 chip oscillate ? Is your USB connector wired correctly ?
Old 14th January 2011, 05:11 AM   #7
U meant does the 12Mhz oscillate ?? i checked with an CRO for it i got a near 12MHz oscillation..
USB is wired correctly , is there anyway to check whether PCM is dead or working??
Old 14th January 2011, 05:34 AM   #8
Yes, i mean if the 12MHz oscillates. The 1M ohm resistor and ~27pF capacitors are critical, the chip will not work without them, even if you see oscillation. Show us a photo of your PCB, maybe we can spot something.
Old 14th January 2011, 05:59 AM   #9
I am onto it as a prototype , so my PCB is still on its way... i have a not so good picture of it , but i don think you will be able to track the lines and all sorry....
Old 14th January 2011, 06:03 AM   #10
That looks nasty. Build a PCB for it.
Problem with connecting PCM2707 to USbHide this!Advertise here!
FS:USB DAC with PCM2707+AD1955 bbp Swap Meet 4 19th September 2007 12:38 PM
Pcm2707 Usb->i2s Rocky Digital Source 0 21st October 2005 01:35 AM
which USB to I2S cct for PCM2707? sceglar Digital Source 0 29th August 2005 01:23 PM
Copyright ©1999-2017 diyAudio
