| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Phase B of mods:
B1. OpAmps u317, u318 changed to AD797ANZ B2. Main board p/s c183,188,189 changed to Panasonic FR 470uF 25V (meant to have done as part of Phase A). A little clearer, more detail and separation between instruments, base string vibrations more naturally prolonged. Also confirmed with Fostex T50RP headphones plugged into amp. |
#12 |
Phase C of mods:
C2. Installed the Audio-gd JZ-1 module (with combined Low jitter clock and Class A supply) - Disconnect pin 4 of U314 (TC74HCU04AP IC). I.e. unsolder and pull/bend up - Wire 1/3FO (11.28MHz setting on 33.86M Type 1 module) to pin 1 of U314 - Wire GND on same side as 1/3FO between ground and C330 - Wire DC input from U301 (NJM78M15 voltage regulator) pin which provides +15V - Wire GND next to DC input of JZ-1 to negative side of capacitor C306 (next to regulator) Sound improvements are very noticeable to say the least. In order of magnitude. 1. More separation between multiple vocals (eg backing vocals) and better instrument placement 2. Vibrations of instruments such as didgeridoos and baritone brass are more realistic/pronounced 3. Singing tones have more sounds coming from back of mouth and throat (for singers/recordings that can produce/capture those dimensions of vocals) 4. Handles percussion with more attack and settles faster 5. Little bit less congestion at HF and complex passages Xavier Rudd's "Food In the Belly" show off these differences well. |
| rotel rcd 975 | naladog | Digital Source | 9 | 2nd January 2012 09:24 PM |
| muting transistors / Rotel RCD-975 | androll | Digital Source | 15 | 10th January 2011 04:31 PM |
| Suggestions where to send my Rotel RCD-975 | Skeetdaddy | Digital Source | 7 | 4th May 2009 03:07 PM |
| Looking for Schematic for Rotel RCD-975 CD Player | dtm1962 | Digital Source | 1 | 19th February 2008 01:14 AM |
| Page generated in 0.07340 seconds (68.67% PHP - 31.33% MySQL) with 11 queries |
