Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th January 2011, 01:31 AM   #1
Default Budget Toslink to stereo analog
I have my TV's analog L/R outputs connected to my vintage stereo system. This works, but the TV has a rather dismal S/N. I can hear hiss when the program material gets soft. The hiss is even there when the TV is muted. The TV has an optical output, I believe it's called Toslink. I figure the digital output would have a better S/N, but I would need a device to convert it to analog L/R. Can anyone recommend an inexpensive small converter? If there is a kit out there, that would be super.
Bobby Dipole
Old 7th January 2011, 04:55 PM   #2
Mooly's Avatar
I would imagine the optical output of the TV is just normal SPDIF standard. TOSLINK is the common optical connection system, not the format.
So you need a DAC or amp that has either optical SPDIF inputs or maybe even have a go at building an optical to "coax" convertor and feeding that into a "normal" DAC that accepts electrical inputs.
I use a Sony MiniDisc recorder with a Pure DRX701 DAB tuner via SPDIF optical and the recorder also works with optical outputs from DVD players etc with no problem.
A simulation free zone. Design it, build it, test it.
Old 7th January 2011, 11:56 PM   #3
Pano is offline Pano  United States
Pano's Avatar
This one will do what you need.
Digital to Analog Audio Converter Optical / Coaxial / USB | Parts-Express.com
Stereo only.
For 5.1 there are a lot of el cheapos on eBay like this:
Cheapo DAC
I have one like it - they all seem to be based on the C-Media chips. Works OK.
How fancy did you want? What's the budget?
Take the Speaker Voltage Test!
Old 8th January 2011, 02:26 PM   #4
I'm enjoying the sounds of the Mini Dac from eBay:
HIFIDIY.net Mini 1793 SPDIF DAC Board -PCM1793+DIR9001
There are a couple of sellers and you can get it with or without case, power supply, etc. Opamp output is socketed, so you can upgrade (I used LM4562, which made a noticeable improvement).
I think there's a USB version if you need the added flexibility.
--Buckapound
For sale: Ultra Analog DAC, Ultra Analog AES20, HDCD filter mihow2007 Swap Meet 1 27th February 2011 06:33 PM
Digitally controlled analog Input/Output stereo audio processor tolaemon Chip Amps 3 17th January 2011 09:08 AM
Low budget FR build for a cheap micro shelf stereo. 5wrms, what driver to go with? nobb Full Range 16 26th October 2009 05:15 AM
toslink to analog, D/A, DAC, lack of low-cost options mnr102 Digital Source 7 24th November 2007 07:53 PM
Stereo amp and speakers on a budget hifipenguin Everything Else 2 11th April 2005 06:40 AM
Page generated in 0.07876 seconds (71.58% PHP - 28.42% MySQL) with 10 queries
