Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th January 2011, 07:40 PM   #1
Default Looking for usb flashdrive player for DCX2496
I have been looking for some time now and have not been able to find a way to play WAV files from a USB flash drive player using AES/EBU to my Behringer DCX2496 digital input.
Any ideas? Will I have to make a player?
Thanks Andy
Old 6th January 2011, 08:15 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Any player with electrical SPDIF out should do the trick. Of course not Toslink/optical.
But any unbalanced SPDIF or balanced AES signal I've thrown at the DCX works.
What troubles are you finding?
Old 6th January 2011, 08:16 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Thanks Andy
Andy,
Not sure I understand what you need - a USB to AES/EBU converter?
jan didden
/Another new issue: Linear Audio Volume 3!
Old 6th January 2011, 08:46 PM   #4
I want to put WAV files on a USB flash drive and then play them thru the DCX2496 without doing all the D/A and A/D convershoins.
As far as I can tell I can not put S/PDIF signals into the DCX2496 AES/EBU input without some kind of adapter. So I would like a player for the USB flash drive with AES/EBU XLR output.
Andy
Old 6th January 2011, 08:48 PM   #5
Sorry I am new to all the digital stuff. How do you get it to work?
Andy
Old 6th January 2011, 09:23 PM   #6
Does it have to be USB? If not, have a look at the QLS QA550, which plays WAV files from SD cards.
--Buckapound
Old 6th January 2011, 09:49 PM   #7
I didnt think the QA550 had digital output. The QA350 is like the closest that I have come to meeting my needs but it has coaxl output (S/PDIF) not the XLR (AES/EBU) that I need. It dose not need to be portable in fact rack mount is preferred to go along with my Ultradrive. Andy
Old 7th January 2011, 01:49 PM   #8
Pano's Avatar
You don't need no stinkin' XLR out.
Just make an RCA to XLR (Male) cable. Connect RCA ground to XLR pin 3, RCA center to XLR pin 2. This should work fine. "If" there are any ground problems, just put a little jumper between pins 1&3 on the XLR.
The Qa-550 has coax out, too - so you can use that if you like.
Old 7th January 2011, 01:51 PM   #9
The QA 550 ONLY has digital outputs. The QA 350 has digital and analog outputs--confusing numbering, I know.
--Buckapound
Old 7th January 2011, 02:13 PM   #10
Pano's Avatar
Good point! The 350 would be easier to monitor (solo) because of its headphone jack.
Speaking of which... Why would you want to go directly from the player to the DCX? Wouldn't you go thru a mixer first? How would you control volume if directly connected? How would you mix in a VOG mic?
DCX2496 USB Input Will Digital Line Level 6 12th April 2012 01:05 PM
Looking for a good CD player with USB flashdrive player 4pyros Digital Source 1 1st January 2011 05:42 AM
USB host audio player? star882 Parts 2 18th April 2009 06:36 AM
Using a CD player -AS- a DAC, via USB... rja Digital Source 5 19th April 2007 01:20 AM
mp3 player with usb i2s output guglielmope Digital Source 1 3rd October 2006 07:07 PM
Page generated in 0.09693 seconds (80.65% PHP - 19.35% MySQL) with 10 queries
