Marantz CD-17 Mods - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th February 2011, 08:35 AM   #21
QSerraTico_Tico's Avatar
Smile working
Originally Posted by Thomo View Post
LOL. Strange, I've done it a few times now. My CD17 runs a fully discrete I/V and output stage.
Index of /images/Marantz CD17
Cheers, Lee.
Hi Lee,
From the picture and comparing with the service manual I concluded you removed all components connected to the internal opamps.
I gave it a try and it works indeed with external opamps of my choice, thanks!
I am still interested what you were using as IV.
Old 30th March 2011, 06:44 AM   #22
Question IV
It was a few years ago, but I'll see if I can dig it out. No promises tho, I may not have it.
Cheers, Lee.
Hi Lee, Perhaps you can elaborate a bit about which type of IV-converter you were using.
Old 30th March 2011, 08:01 AM   #23
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Hi. I can't find the schematic anywhere now.
I designed it myself and from what I remember it was based on this.
However, I'm sure I removed the filters from the inputs and placed one per channel on the output. I then used an extra single-fet buffer to drive the output.
Sorry I can't be of more help.
Lee.
Old 30th March 2011, 07:35 PM   #24
Many thanks Lee
Old 30th March 2011, 10:37 PM   #25
Fidelity Audio's Avatar
Oscon SEPC are a must on the digital rails in these players, the details are improved quite a bit. Dc blocking caps are not needed either.
Also replacing those samwah will bring big gains (I have issues with those caps )
Brent
Old 7th May 2013, 09:30 PM   #26
ucciopino's Avatar
I have a problem with this player on the muting circuit but is not related to the 4 output transistors muting but something that acts on the 2114 ic.
Sometimes just turned on is fine for a few minutes ....... then the sound starts to crackle on both channels and the level drops until almost disappear
Can anyone explain the functioning and utility of the command "P-OFF" (I think that's giving me problems ....... C814 on LPS 5v?)
Thanks and sorry for my english.
Giuseppe.
at
Old 7th May 2013, 10:13 PM   #27
ucciopino's Avatar
P.S. In the mod are not used (in the dac and psu) a bypass caps ....... deliberately?
Old 9th May 2013, 11:54 AM   #28
Send a message via MSN to audio_tony
I did fit a load of 100nF bypass caps - and I ran into a problem, which I thought had been caused by the addition of these caps, but I had splashed solder on the PCB - I only saw this *after* removing all the 100nF caps!!!
I never did refit them...
Visit the Vintage Technics Website - recently upgraded! The cd player daclist site has been upgraded too. (being unemployed leaves one with plenty of spare time..!)
Old 11th May 2013, 06:24 AM   #29
ucciopino's Avatar
Thanks Tony ..... for all.
The service manual i need (first model KIS) is : 74CD17/92B
I bought two LME49990 to replace the 2414 (good choice?)
I go to replace (to test) the output capacitors with a 4.7 uF Mundorf Supreme (which I already have at home).
Unsure if change all capacitors considering the age of the player .......... fragile board can be a problem? ......... any advice to operate?
if I replace all capacitors with a good stuff I will not use bypass.
As soon as I have some money working on the clock.
Old 11th May 2013, 08:16 AM   #30
I did reply to your PM - did you receive it?
I think you mean the NJM2114? in which case you need a dual opamp - the LME49990 is a single...
Also - there's little point to fitting fancy opamps unless you bypass the HDAM stage anyway.
I used some Wima caps in the output stage of mine. 2.2u IIRC.
The schematic I have shows the output caps as 2x 220uF in series - but my player had a single 100uF. So long as you're not trying to drive a very low impedance load, 2.2uF / 4.7uF will be fine anyway.
The capacitors on mine seemed fine when I checked them. It can only be a good move to replace the ones in the digital side with Oscons anyway.
The board wasn't too bad - but if you tweak it too much, I think it may be a problem.
Mods to Marantz CD-6002 arupg Digital Source 14 2nd August 2011 05:35 PM
Mods for Marantz CD 84 sammybarker Music 2 9th December 2008 05:20 PM
marantz cd 17 whats gan on Digital Source 9 28th January 2007 04:20 PM
FS: MARANTZ CD-17 mkIII KI Signature (Europe) cartman Swap Meet 4 22nd October 2006 08:06 AM
Marantz CD-17 K.I. Signature Mk1 - Upgrading ? wytco0 Digital Source 3 2nd October 2004 01:52 PM
Copyright 1999-2017 diyAudio
