| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Thought you might be interested in these. The DAC is a TDA1543 based on a design posted by Peter Daniel... Anyway, starting at pic 1/5... This is the Main CD player's PSU. Closest is the 5V rail. In the middle is the 9V rail. The far end (top) has the negative supply. Notice, the 5V and 9V have snubbing caps and good filtering. Gaz |
#2 |
Pic 2/5...
This is the DAC's PSU. It has large amounts of filtering and puts out a PERFECT 5V! Large space around edges are to help disperse with micro-vibrations from the transformer (or I just had that boad to hand! Gaz |
#3 |
Pic 3/5...
This is the TDA1543 DAC. One BG N 4.7uF cap is missing cause they messed up my order and are now out of stock...3 weeks to wait!!! The resistors in the I/V stage are Vishays and three of the caps (red ones) are BG N. The large black one is an SCR 10uF and the yellow is (obviously) a Hovland (0.022uF). You may notice that the chip is missing - all in good time... ![]() Gaz |
#4 |
Pic 4/5...
I made all of the PCBs in one batch. I was using that Press 'n' Peel Iron-On stuff. It turns out that I had got them ALL the wrong way around...Undeterred (and not wanting to pay another £15 for new sheets of the stuff) I converted the TDA1543 into a SMD and the regulators on the PSUs were turned 180degs. Obviously the bridge rectifiers had to be rotated but most components were unaffected...Luckily! Gaz |
#5 |
Pic 5/5...
Well here they all are...This is just for size purposes really... Hope you enjoyed the little slide show! ![]() Thanks, Gaz |
#6 |
nice work, gaz!
show us some pictures of the whole player, when you'll have finished it. |
#7 |
diyAudio Moderator Emeritus
What schematic did you use for the cdpro2 power supply?
-- Brian |
#8 |
Bricolo:
Ordering the CD-PRO2 is next months expense! I will, no doubt, show you my results!BrianGT: I used the one at A simple but yet effective supply. It seems a bit weird for two reasons...Firstly, they go on about the importance on the 9V coming up AFTER the 5V but within 150mS - However, I don't see anything here to handle that...I'll see if it works or not. The other weird issue was the negative side...I did manage to simulate it here... Gaz |
#9 |
Wow, that looks like some serious kit, what with all those exotic caps and all
![]() Great job, I can't wait to see the player finished. What do you reckon the whole project will have cost by completion? -Simon |
#10 | |
Very nice and clean work Gaz. So next month we will have the power up ceremony, hope you share this experiance with us. Since we can't see a schematic, don't know which is the SCR cap roll. In my opinion an SCR is a no-no on a source or line amp, even on the PSU so I will suggest, further down the road, to test different caps and compare. |
| supply regularly CD-Pro2 module VAU1254 CD-Pro (VAU1252) CD-Pro2 (VAU1254/11) vam1250 | smartech | Vendor's Bazaar | 1 | 10th April 2011 10:02 AM |
| PSU's for CDM PRO2 | simon dart | Digital Source | 7 | 29th November 2005 05:12 PM |
| Help! CD-PRO2 | bsyyu | Digital Source | 4 | 2nd April 2004 09:35 PM |
| CD pro2 | ghee0 | Digital Source | 2 | 12th March 2003 03:39 AM |
| Page generated in 0.11157 seconds (79.97% PHP - 20.03% MySQL) with 11 queries |
