Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th September 2003, 08:45 PM   #271
Originally posted by kairon
Would the DS80C320 (8052 compatible) be a good chip for controlling something like a cd drive?
For play,stop,fwd,rev and pause, the DS80C320 would be enough. For anything more complex e.g. playing back audio through the IDE interface, the DS80C320 will not be enough.
ray.
Old 8th September 2003, 08:52 PM   #272
Default Re: Clock division for CD ROM transport
Originally posted by Oli
I Picked up a cheap NEC CDR500 CD ROM drive at the weekend (SCSI). I have already taken it to pieces- a nice aluminium cast assembly like a CD-PRO mechanism. Unfortunately I was not too observant and there is no S/PDIF out! Looking on the board I have found a TDA1545A (with I2S bus). I wish to use the I2S, together with a CS8402A to provide me with a nice S/PDIF output so I can use with a variety of equipment (I know it is not the ultimate!) Of course I am going to reclock the transport. Currently the clock operates at 384 x fs (44100). However the Crystal Semiconductor transmitter only operates at 256 x fs
My question to others is- will a divide by 1.5 clock divider circuit (using flip flops and logic) result in significant jitter? Is there an alternate transmitter on the market that will operate from 384 x fs (44100) ?
AKM AK4101/AK4103
TI DIT4096/DIT4192
ray.
Old 8th September 2003, 09:15 PM   #273
Oli is offline Oli  United Kingdom
Default Cheers!
Just checked the data sheet for the first item you suggested- It seems to be just the ticket- no clock devision required!
CHEERS!
Oli
Old 9th September 2003, 04:27 PM   #274
Matttcattt's Avatar
Originally posted by Lupulroz
Mattcatt, in your schematic couldn't be 16F84 (only 18 pins). Anyway I'm working on a version with 16F8xx that supports LCD display and remote. The first attempt of sound will be with AD1892 receiver with some reclocking.
The ATA specs are really a mess; I hope I can transform data into I2S with a help of a CPLD; otherwise a DSP will be the only alternative to make a good standalone CD.
oops, im so used to typing it, i forgot its meant to be a PIC16F877.
i hope to hear of your project
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 9th September 2003, 04:29 PM   #275
Matttcattt's Avatar
also, i have not had any answer about the DACs. the links are:
One Two Three
Old 9th September 2003, 05:14 PM   #276
For sure I will not go for a dac with digital filter inside.
Old 9th September 2003, 08:56 PM   #277
frenzic is offline frenzic  Netherlands
Me neither.
Old 14th September 2003, 08:13 PM   #278
Matttcattt's Avatar
Originally posted by frenzic
Me neither.
why?
could someone point me to a DAC tutorial? the datasheets are not very helpful.
Old 15th September 2003, 12:22 AM   #279
Originally posted by Matttcattt
why?
Fashion? Dogma? Satan uses a dac with a built-in filter?
Not a tutorial and based on rather old IC's, Analog Devices' AN-394 application note gives a useful insight into the design of a dac and AN-283 covers the bitstream type dacs, the type of dac ic that usually comes with a built-in filter.
You might also find this useful
http://members.chello.nl/~m.heijlige...tml/dactop.htm
ray
Old 15th September 2003, 01:21 PM   #280
Matttcattt's Avatar
ray
thanks, ill have a look when i have a chance.
Page generated in 0.11065 seconds (75.89% PHP - 24.11% MySQL) with 11 queries
