Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th December 2010, 02:54 PM   #1
Sunsun22's Avatar
Default Is this a better clock?
I have a DIY CDPro2 Transport purchased from hifidiy dot net. It has been running in my system for 1.5 years. It went through a number of modifications over the span of service on power regulator by changing the LM317 to LT1085 then to DEXA UWB regulators then to adding DEXA UWB regulators for individual parts (oscillator, TL etc.). I can denote improvement on every modification and is totally satisfied with it. Yet, even without any modification, this DIY transport blows away my CEC TL51X transport which is about the same cost. After the latest modification, it even blows away a Wadia 8.
I think it is time to try out the clock. I borrowed a clock from my friend and tried but I cannot get it working. I think I need some time to find out the reason. I also measured the output but the waveform looks alike between the original oscillator and the clock. Is there any way to denote which could be the better alternative?
The original oscillator output
Old 9th December 2010, 02:55 PM   #2
Sunsun22's Avatar
This is the output from the clock (diyhifisupply.com)
Old 9th December 2010, 05:47 PM   #3
DF96 is online now DF96  England
Your new clock looks more noisy than the old one!
Anyway, the (perceived) issue with clocks is jitter. Jitter has to be quite bad before it is visible on an oscilloscope display. You need some fancy test gear to measure jitter.
Old 9th December 2010, 09:50 PM   #4
It there DC in your friend's clock? In some cases, the players stop work with DC clock signal. Try to add a coupling cap at the output of your friend's clock.
Here's looking at you, kid.
My CD Clock - the "Kwok Clock" kwokm Digital Source 13 10th September 2006 12:34 PM
CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation stolbovoy Digital Source 7 3rd December 2004 07:18 PM
Audiocom clock vs. LC Audio clock KevinLee Digital Source 22 26th July 2004 01:29 PM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
Page generated in 0.08912 seconds (74.08% PHP - 25.92% MySQL) with 11 queries
