Teralink X2 clock mod. with Tentlabs XO - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th January 2011, 04:21 PM   #41
crt is offline crt  Indonesia
crt's Avatar
Originally Posted by dvb-projekt View Post
Thatīs not the Teralink X2.
I donīt know this one you have, so i couldnīt answer this question.
Ops Sorry, i thought this the "naked" version of Teralink X2
But if i look at the chip almost the same (i use the same ASIO driver from teradak and no problem)
The difference only at Regulator, capacitor, pulse transformer and of course layout
about to turn on this device :
- applied external supply first and then plug the USB
- or Plug the USB first and then applied external Supply
Which one do you prefer ?
Old 17th January 2011, 04:51 PM   #42
dvb projekt's Avatar
Apply the external supply first and then plug the USB.
Reference TDA1541A DAC project PCBīs / Tube-I-zator PCB
Stock status in my Blog
Old 20th January 2011, 11:16 PM   #43
Jogi is offline Jogi  Germany
I had some time yesterday and finally got all parts together to start with the 3.3V shunt.
It is working, but when I connect it to the Teralink, it is not seen by the computer...
I took out the 3.3 reg and the 100ĩf cap, as Oliver did, and connected the negative rail to the switch, where also the neg rail from the 5V shunt is connected. I have a 17R resistor for R1, which gives about 100ma over this resistor.
So it should work, but it doesn`t...
I put the onboard reg and cap back, and it is working normal again, so the chip is still o.K.
Did I forget something? Do I have to take out something else?
btw does anyone know why I cannot use the smilies? Not my day today...
Old 21st January 2011, 12:58 AM   #44
o.k., I tried it a second time, and now it works, strange enough. Soundwise it is ..eh..different. Seems to be clearer, and more detailed and dynamic, but difficult to say from memory. In my experience the shunts need some time to "ripe", so it will improve next days.
But still no smielies possible...
Old 21st January 2011, 08:53 AM   #45
crt's Avatar
@DVB-PROJECT
Because my DAC can ACCEPT I2S Directly
Is that recomended to remove those I2S Buffer ?
the place between DAC and "Teralink" is pretty close around 10cm only
Me, sometimes i plug the USB and NOT Recognize too
but i just unplug and then plug again --> then work
Can you post a picture ?
La Ode
Old 21st January 2011, 09:13 AM   #46
Originally Posted by crt View Post
@DVB-PROJECT
Witch DAC are you using?
Old 21st January 2011, 02:25 PM   #47
crt's Avatar
B.Y.O.B DAC --> My Own DIY DAC
Using DF1704 for Digital Filter
My Plan is put the "teralink" in the same box, so i can keep the gap between two device as close as possible
Old 21st January 2011, 02:38 PM   #48
Looks nice I would let the I2S Buffer IC on itīs place to prevent any problems.
Old 24th January 2011, 06:03 PM   #49
ferynov is offline ferynov  Indonesia
ferynov's Avatar
Send a message via Yahoo to ferynov
Wow This Nice DAC BYOB .... salute , BYOB i mean Build Your Own Board ..... peace !...
-Best Regards-
diy blog
Old 23rd March 2011, 09:07 PM   #50
wushuliu's Avatar
I have just swapped out the LT1084 with regulated 5v. I get green light but no sound and X2 is recognized. Then I realized that 3.3v is separate from 5v. Does this mean I need to use another DC adapter for the 3.3v (I cant use 3.3v shunt)? The 3.3v is not powered by the 5v, right?
Teralink X2 edodo PC Based 37 22nd December 2011 04:32 PM
Teralink-X2 & Power Supply unit A&B-SYSTEMS Vendor's Bazaar 1 5th October 2010 07:03 PM
Swapping oscillator on a Tentlabs XO Clock3 Groundloops Digital Line Level 3 12th June 2009 09:46 AM
Selling Tentlabs XO Supply Ruach Swap Meet 0 3rd July 2006 07:56 AM
For sale: Tentlabs XO-DAC hifi Swap Meet 0 25th May 2006 03:31 PM
Copyright Đ1999-2017 diyAudio
