Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Teralink X2 clock mod. with Tentlabs XO
Old 20th December 2010, 07:40 PM   #31
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by glt View Post
Nice project!. Questions: Since the chip is a 3.3v chip, are you feeding a 5V clock? Thanks.
the clock runs on the 5V line, correct.
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 20th December 2010, 08:30 PM   #32
Jogi is offline Jogi  Germany
Oliver,
thanks for being the pioneer and watering our mouths...unfortunately X-mas is in the way, so I will try it in 2 weeks.
So it seems to be true: it all depends on a decent power supply. Hail to Salas again!
Ciao,
Juergen
Old 23rd December 2010, 11:27 AM   #33
gabanyayaya is offline gabanyayaya  Malaysia
oliver
how much current you set for the X2 5V and for the 3.3V ? I can't see the resistor value for adjusting the current on the shunt boards...
Old 23rd December 2010, 01:01 PM   #34
Originally Posted by gabanyayaya View Post
oliver
For the +5V line i use a 10R (2V/10R=200mA), for the 3.3V line a 22R (2.3V/22R= 104,5mA).
Old 15th January 2011, 03:26 AM   #35
crt is offline crt  Indonesia
crt's Avatar
Nice Thread
I have this Teralink X2 too and will modified soon
Will use Shunt Reg 1.1 by Salas too
Have you measure the real current needed for each Voltage ?
Sorry for my poor English
La Ode
Old 16th January 2011, 08:31 AM   #36
The needed currents are as followed:
+5V line: 55mA (with TendLabs clock and USB-Isolator downlink)
+3.3V line: 19.5mA
Best regards,
Oliver
Old 16th January 2011, 12:45 PM   #37
crt's Avatar
Thank's for the answer
Ok, i will follow you to make separated supply for 5Volt and 3.3Volt
BUT still using onboard Clock
btw
When i plug the Teralink to my USB Computer, it recognize by windows even i did not give a power to Teralink
Is this normal ? i mean, This Device can work using USB power only ?
Old 16th January 2011, 06:02 PM   #38
Sure, you have a switch to choose if you want to use the USB power or an external power input
Old 17th January 2011, 06:12 AM   #39
crt's Avatar
I Ordered this one
Native 24bit 96k USB to Spdif I2S Converter Module DAC - eBay (item 270688442049 end time Feb-04-11 06:30:58 PST)
Which did not have the switch.
How to deactifated onboard Supply ?
Old 17th January 2011, 09:23 AM   #40
Thats not the Teralink X2.
I dont know this one you have, so i couldnt answer this question.
Teralink X2 clock mod. with Tentlabs XOHide this!Advertise here!
Teralink X2 edodo PC Based 37 22nd December 2011 03:32 PM
Teralink-X2 & Power Supply unit A&B-SYSTEMS Vendor's Bazaar 1 5th October 2010 06:03 PM
Swapping oscillator on a Tentlabs XO Clock3 Groundloops Digital Line Level 3 12th June 2009 08:46 AM
Selling Tentlabs XO Supply Ruach Swap Meet 0 3rd July 2006 06:56 AM
For sale: Tentlabs XO-DAC hifi Swap Meet 0 25th May 2006 02:31 PM
