Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Teralink X2 clock mod. with Tentlabs XO
Old 12th December 2010, 07:10 AM   #11
gabanyayaya is offline gabanyayaya  Malaysia
Originally Posted by jeffery8341 View Post
Hi, What a amazing work, I have an External Teradak DSIX + Re-Clock board, do you think the TXCO can be swapped like you did? Thanks.
jeffery8341
where to you buy this board?
Old 12th December 2010, 08:38 AM   #12
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Hi Jeffery,
that is no problem.
But dont forget that the XO needs a perfect clean +5V line to keep a low jitter clock output signal.
The build in LM1084 should be swapped to a good shunt regulator. Therefore you could use an external or the plug in version from Guido here.
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 12th December 2010, 08:44 AM   #13
Originally Posted by gabanyayaya View Post
thanks oliver,
BTW for this kinda mod can it be applies and implemented to every digital devices with a XO like a CDP or maybe a DAC board or any usb converter?
Regarding you USB isolator is it necessary to runs it with a Independent shunts?
Sure you could apply Guidos XO in every CDP or DAC. You find all needed informations on his Tentlabs webside.
The USB-Isolator runs with the same shunt as the X2.
What i am thinking about is to cancel the onboard LC-Filter on the X2.
This is for the standard TCXO and i dont want to go back.
Old 12th December 2010, 09:27 AM   #14
Oppsss
Sorry Oliver, maybe I've said it wrongly. I beg your pardon.. What I mean from my question previously is that does the additional RF choke and decoupling cap for the XO really help improve the sound for each digital devices with XO?
So is this means that X2 and the USB-Isolator sharing the same shunt OR X2 and the USB-Isolator has its own shunt each...sorry for this confusing part
Old 12th December 2010, 09:52 AM   #15
Oppsss
The additional RF choke and decoupling cap for the XO is recommended by Tentlabs and comes with the order.
The X2 and the USB-Isolator sharing the same shunt!
Old 12th December 2010, 09:57 AM   #16
Thanks Oliver.
This might be a good cheap M2Tech hi Face replacement for me. Can't wait to do this....
Old 12th December 2010, 10:55 AM   #17
jeffery8341 is offline jeffery8341  Taiwan
Hi Jeffery,
that is no problem.
Thanks Oliver, but this board request 12V-1A, and I can't find anyplace to purchase Tentlab XO in both Taiwan and China, so I think I have to give up, but I want keep seeing your great work, maybe I can learn something from you in the future, thanks again.
Old 12th December 2010, 11:00 AM   #18
jeffery8341
Taiwan
Old 12th December 2010, 11:31 AM   #19
Jefery,
your pcb works with +5V (LM1084-5 output = +5V).
What would be interesting is the needed current. BTW, never ever 1A!
Measure the current. If it is under 80mA, you could use the Tentlab plugin shunt.
If its more, you could use quanghaos Salas shunt here.
I am sure Guido Tent ships also to Taiwan
Old 12th December 2010, 02:08 PM   #20
Marlowe is offline Marlowe
Why don't you order from Tentlab directly?
Here's looking at you, kid.
Teralink X2 clock mod. with Tentlabs XOHide this!Advertise here!
Teralink X2 edodo PC Based 37 22nd December 2011 03:32 PM
Teralink-X2 & Power Supply unit A&B-SYSTEMS Vendor's Bazaar 1 5th October 2010 06:03 PM
Swapping oscillator on a Tentlabs XO Clock3 Groundloops Digital Line Level 3 12th June 2009 08:46 AM
Selling Tentlabs XO Supply Ruach Swap Meet 0 3rd July 2006 06:56 AM
For sale: Tentlabs XO-DAC hifi Swap Meet 0 25th May 2006 02:31 PM
