Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd December 2010, 08:33 PM   #1
Default CD player jumps at 1'30 on track 1 every time
Hi I've got a Philips CD732 which i like the sound of but I've noticed it jumps once at between 1'30 and 2'00 on every CD I put in. I did open it up a few months after I got it and played around a bit with blu tack to increase rigidity but took it out again later after I noticed the skipping. I can't remember it happening before then but if you skip tracks it doesn't happen so maybe it was doing the same before that but I never noticed.
Any ideas if there's an easy solution?
Thanks, lawrence001
Old 3rd December 2010, 03:02 AM   #2
georgehifi's Avatar
Send a message via MSN to georgehifi
Someone may have paused it for a very long time at this time, which can cause wear on the gears or sled tracks as the laser sled moves back and forth when in pause on some machines. Or you need to clean the laser carriage tracks of some debris or blutack that has stuck to the tracks.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 3rd December 2010, 11:09 AM   #3
Mooly's Avatar
Is it a CDM12.1 or 12.4 mech like this. If so solidified grease is usually the issue. Only 100% cure is to fully dismantle the gears (two white ones in this picture), clean and wash them, remove grease from the "rack" on the pickup, reasemble and re lube with suitable plastics compatable grease. If your gears are the soft blue nylon ones the teeth were prone to damage.
It's not particularly difficult, but you have to dismantle it all to do a proper job.
A simulation free zone. Design it, build it, test it.
Old 10th January 2011, 03:29 PM   #4
Thanks for your advice guys, I'll take the cd12 mechanism apart if I can work out how to do it, not many screws in sight! Lawrence
CD Player Skipping on First Track delory Digital Source 7 10th August 2010 09:05 PM
CD Player canīt read CD before 5mins. on-time Maxxtr0 Digital Source 4 9th August 2010 09:29 PM
CD Player Ocassionally Can't Lock on Track DreadPirate Digital Source 4 23rd March 2009 08:50 AM
x-meridian, time to toss your cd player? DJNUBZ Digital Source 5 22nd February 2007 03:17 PM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
Page generated in 0.07502 seconds (69.58% PHP - 30.42% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
