| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi to all,
i would use the WM8804 to convert the S/PDIF to I2S (16bit). The I2S should feed my TDA1541A NOS DAC. Unfortunately i have no sound output , independent if i set the I2S to 16 or 24 bit (AIFCONF0 1 or 0).Malka07 use the same DAC pcbīs from me and have also no luck. The connections are as follows: LRCLK to TDA Pin1 BCK to TDA Pin2/4 Data to TDA Pin3. Can someone help? With my Teradak X2 USB to I2S converter, everything works fine! Best regards, Oliver
Reference TDA1541A DAC project PCBīs / Tube-I-zator V2.0 PCB / SSHV-Shunt PCB /
Pedja Rogicīs Discrete Diamond Non-Feedback I/V Stage - Stock status in my Blog Last edited by dvb-projekt; 27th November 2010 at 10:18 AM. |
#2 |
Is there any output on the pins of the WM8804? Check for a LRCLK (pin15) at least.
Also, note that the datasheet has an example for 16-bit right-justified audio, not I2S. This bit me once trying to use a WM8805... I don't know the twisted pear board sufficiently well to be of any other advice. Good luck! |
#3 |
Hi Oliver,
I've checked my setup(TP 8804 into TDA1541a NOS) and had a look at the TDA data sheet and it looks like pin27(OB/TWC) on the TDA has to be pulled high(connected to pin28/VDD/+5v) to allow it to accept multiplexed two's complement/I2S input. Might be worth checking in your setup. Regards Cornelius |
#4 |
Hi Cornelius,
thanks for the advice, but it is on the +5V line. Best, Oliver
Pedja Rogicīs Discrete Diamond Non-Feedback I/V Stage - Stock status in my Blog |
#5 |
I2S 16bit
#6 |
Pedja Rogicīs Discrete Diamond Non-Feedback I/V Stage - Stock status in my Blog Last edited by dvb-projekt; 28th November 2010 at 03:40 PM. Reason: Setting picture added |
#7 |
hi
I am using WM8805, WM8742, but I think this should be good to 8804 WM8804--TDA1541 16bit I2S hardware 1--H 2--L 3--L 4--L 5--Unlock(3v3-10k-led) 6-- 7--3V3+ 8--AGND 9-- 10-Xtal 11-Xtal 12-Data out 13- 14-Bclk-out 15-LRck-out 16- 17- 18-DGND 19-3V3+ 20-Spdif-IN |
#8 |
Can you please confirm there is at least LRCK signal? (if you have oscilloscope, that is). If you don't have oscilloscope, simply measure DC from LRCK to GND and report back. Measure DC with and without music playing.
Also, what are the status LEDs saying? All off? Last thing which comes to mind: is the DAC powered from the same supply? If not, you might need to also connect the GNDs of the 2 boards? |
#9 | |
I have the same dac as Oliver(Dvb-projekt) and am also having the same problem. I dont have an oscilloscope, but i measured dc from LRCK to GND with and without music playing and both times i got 1.64v. All LEDs are green when a coax cable in connected to the dac regardless of if music is playing or not. If the coax is disconnected then all lights are red except non audio which remains green. I have Gnd on my Twisted Pair board connected to Gnd on the dac board. Pictures of the dac can be seen in this thread along with Board layouts etc...maybe that will help too. "Reference" TDA1541A DAC with I2S-BUS architecture Page 1 shows the board layouts....and page 31 onwards, are pics of my dac with the problems im having. Thank you all, for your kind help...i really would like to get to the bottom of this, and im sure Oliver would too. Alon |
#10 | |
Alon,
iīve got an advice from John (ecdesigns) to our problem. Quote:
| FS: Twisted Pear Audio S/PDIF and Metronome | matthewm | Swap Meet | 15 | 11th August 2010 06:46 AM |
| FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF | free2dev | Swap Meet | 4 | 24th July 2010 12:43 AM |
| Twisted Pear IVY II module (built) | n_maher | Swap Meet | 3 | 6th February 2010 11:21 AM |
| FS: Twisted Pear Audio S/Pdif receiver | orthoefer | Swap Meet | 2 | 17th January 2010 04:47 PM |
| Twisted Pear - S/PDIF 4:1 MUX/Receiver Module (new, unused) | n_maher | Swap Meet | 3 | 19th February 2009 04:57 PM |
| Page generated in 0.12817 seconds (80.70% PHP - 19.30% MySQL) with 11 queries |
